Old 09-28-2004, 02:02 AM
ailaz1 ailaz1 is offline
Need your help 91 s10
Hi i just bought my s10 a couple month's ago and the problem is that it run's ok and some day's it dont start up or i will use it to go to the store and then it wont start up the motor only turn's over and nothing. tow it home and then it start's up the next day.i dont know what to check to find the problem because it will run for a couple day's problem free then do it again.if you could help me out i would appreciate it.91 s10 2.5 4 cyl 5 speed.
Old 09-28-2004, 09:48 AM
Mikado14 Mikado14 is offline
Re: Need your help 91 s10
Not much to go on with what you have said, however,,,,
When it doesn't start, have checked:
Fuel pump running (2-3sec) when you first turn on the key?
If it is, did you check fuel pressure?
If it doesn't, check the relay? and/or power?
If it runs (fuel pump), did you check or have you changed your fuel filter?
Just a few beginning ideas.
Old 09-28-2004, 01:55 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
do a tuneup.
Old 09-29-2004, 09:56 AM
flitsct flitsct is offline
Check your plug wires. Especially the center wire from your distributer cap that goes to your ignition coil. If it is corroded and not making goood contact, this may be your intermittent problem. Your coil could be bad also. I also have had the rotor tab break off under the distributer cap. Change cap and rotor. Hope this helps
Old 09-30-2004, 03:14 AM
I thank you all for all your help.at least i have something's to check out i had no idea before.i just wanted to thank you guy's for the help Mahalo.
Old 09-30-2004, 01:04 PM
BlazerLT's Avatar
AF -Advisor
Yea, do a full tuneup with the following:
Spark Plugs (AC Delco R43TS6 Gap 0.060)
Spark Plug Wires
Distributor Cap & Rotor
Fuel Filter
Air Filter.
You should be fine after that.
Oh, and you're welcome.
Old 10-05-2004, 09:01 PM
Walker S-10 Walker S-10 is offline
Spark plugs and wire isn't goin to make it start sometimes, try looking at the relay on the fire wall
sometimes the the wires don't make good contact in the relay
Old 10-05-2004, 10:30 PM
BlazerLT's Avatar
AF -Advisor
Don't discredit my advice. A tuneup on a 13 year old vehicle is never a poor idea.
Old 10-06-2004, 08:12 AM
never said it was a bad idea just not his problem, bad wires or sparkplug will make the truck run like shit
