Old 09-28-2004, 12:16 AM
hellah fresh's Avatar
hellah fresh hellah fresh is offline
timing jump..??
Ok recently i been tryin to make my eclipse run for the past 2 months so heres the story... i went through 4 different ECU and now the 5th one i got i installed it.. now it cranks the same but what it does now i hear my timing jumped... so yout think the whole time it was my timing that was causing my car not to turn over? we never heard the timing jump untill we installed the 5th ECU. =\ i hope thats the problem.
1996 Mitsubishi Eclipse RS -Red ****UPDATE**** My car is no more! R.I.P. 12/12/05
Mods: 420a DOHC equipped with: bored 54mm throttle, 2.5" cold air intake, 2.5 chrome headers, 2.5 Down Pipe, 2.5 resinator, 5" 2.5 flared muffler, 2.5 custom piping, Megan front & rear strut, Megan rear lower tie rod, Monroe Shocks, Aerospeed coilovers
Rollers: 18" TSW Throphy / Pirelli P7000 225/40/18
Old 09-28-2004, 12:37 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: timing jump..??
i have never heard timing jump and all the times that i have had timing jump i think i would have heard it... anyways what did it sound like?`
Old 09-28-2004, 04:08 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: timing jump..??
You made no mention of what kind of car this is, but I'll assume its a 90-99 turbo. NT4g63s are probably the saem in thsi regard. NT 2G? youre on your own.
Put the crank pulley timing mark at the TDC or zero mark or whatever the hell they labeled it on the timing belt cover. With the uppper tbelt cover off make sure the timing marks are aligned with the dowel pins at 12 oclock. It really is that simple. For a quick check anyway
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-28-2004, 07:07 PM
Re: timing jump..??
its a 96 RS it sounded like a gulping sound from the heads. Like its not firing in the correct order? but a gulping sound. =\
Old 09-28-2004, 07:08 PM
Re: timing jump..??
its not turning over.
Old 09-29-2004, 04:47 AM
EclipseRST's Avatar
Banned
Re: timing jump..??
you cant turn the motor over by hand even? did ya make sure the clutch is in and/or its not in gear?
