Old 09-27-2004, 10:28 PM
tasha99gs tasha99gs is offline
Send a message via AIM to tasha99gs Send a message via MSN to tasha99gs
belts, pulleys, etc...
ive got a 99 gs, ive replaced the belts on it 3 times and for some reason one keeps ripping. at first a part of it peels off and then the rest of it rips up. it has never gotten bad enough to where the belt came apart but bad enough to be replaced. i have made sure my pulleys and stuff are tight enough and what not but im running out of ideas and i dont know what to do. anyone got any advice? last time it ripped was just the other day and it was while i was in high rpms, are there higher quality belts other than the ones that like autozone or a parts store carries?
Old 09-28-2004, 12:11 AM
joemathews's Avatar
joemathews joemathews is offline
Re: belts, pulleys, etc...
Many people claim dealership parts are better; for something as simple as a belt, it doesn't seem like there should be that much of a difference. Check your pulleys for any sharpness and make certain that your belts are firmly seated in teh pulleys' ruts.
1996 Eagle Talon
Old 09-28-2004, 08:31 AM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
there ARE differences in belt quality. I got a cross-thatched grip aftermarket pattern on my 97 turbo, they started to slip and burn on the pulleys. Put OEMs back on, not a single squeak, nothing, silk smooth....so yeah, try the OEMs.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 09-28-2004, 01:54 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
I am guessing that you are talking about the power steering belt. I have been though two in the last year. There is a TSB out on it and the parts cost about 150+, not worth it IMO. I just went out and bought a lifetime warranty bely from murray's
For Sale 98 Eclipse GS, 5 spd
Old 09-28-2004, 04:48 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Make sure that the pulleys are square with each other... When I first got my car the steering pump was out of line and caused the belt to shift to one side and it pretty much started to take off one rib at a time... If not that problem... ?dunno
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 09-28-2004, 06:18 PM
bclipse bclipse is offline
Do you have any mods like an UDP? Because if you do make sure it has the same amount of grooves as all your other accessories
95 GS-T
'cause everyone thinks they're right, and nobody thinks that there just might
be more than one road to our final destination
Old 09-29-2004, 04:13 AM
kjewer1 kjewer1 is offline
AF - Advisor
Ashah and Spyder mentioned what I am thinking about. I know the turbo cars have a TSB on accessory belt misalignment, and I believe the NTs do to (ashah backs this up from the sound of it). For the turbo cars you can often jsut shim up the offending accesory.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-29-2004, 07:35 AM
ashah000's Avatar
Kevin what do you mean "you can just shim up the offending accesory".. maybe i can try to see if it works on the NT
Old 09-29-2004, 02:20 PM
AF - Advisor
I havent read the TSB in a long time. But depending on which way it has to move you can move the mounting brackets accordingly, or move the pulley out. You'll have to see if you can figure out which way the pulley/accessory has to move, then find a way to do it.
Kevin Jewer
