Old 09-27-2004, 09:57 PM
tenz0's Avatar
tenz0 tenz0 is offline
Send a message via ICQ to tenz0 Send a message via AIM to tenz0 Send a message via Yahoo to tenz0
3rd gear grindage
car info: '90 civic hatch - '94 b18b1 motor / ys1 transmission
for a little background, ive gone through two trannies already and am on my third...if im right about this, feel free to flame the fuck out of me...
my transmission has been grinding in 3rd gear, just slightly, when i shift into it...i started thinking maybe it was because the clutch cable wasnt adjusted properly since this was the 3rd grinding transmission ive had, it couldnt just be shitty luck...so i go and adjust it a little bit, and now 3rd gear doesnt grind when i shift to it, but 5th gear does...
should i keep adjusting and eventually my problem will be solved, or is my tranny just screwed???
http://conxept.cjb.net
http://ef-honda.com
pure.Honda member since april 2000...r.i.p.
-my hatch
Old 09-28-2004, 03:24 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: 3rd gear grindage
Hmm damn dude, keep playin with it. My boy did the same on his integra. His other friend cut the cable short so he can have that "quick" shift. Which is totally bullshit. Anyways his gears started to grind crazy and it was harder to shift.
Old 09-28-2004, 05:55 PM
dagoEF's Avatar
dagoEF dagoEF is offline
I would recommend changing the fluid to that Synchromesh stuff if you aren'y using it already, that might help. You could also use some Lucas oil in there too, that should work. I got a used ys1 from a guy that said it grinded a little, I used a mixture Synchromesh and Lucas and I've never had a grinding problem. Just a thought. Also try adjusting the cable too.
Old 09-28-2004, 07:53 PM
rushb18 rushb18 is offline
Yea i seen a thread in another site said to drain your tranny fluid and put new in use it and then drain it again..They said the cause was the shavings getting caught on the syncros or something when shifting and gives it a grind..Thats just what ive seen on forums so i dont know if it works..Good luck..
Old 09-28-2004, 09:37 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
just so everyone know, Synchromesh is made by GM and you have to buy it at a dealership, its definaly the best tranny fluid made.
Old 09-29-2004, 12:14 AM
mellowboy's Avatar
B16a trannies are garbage.My J1 was like that also.
Old 09-29-2004, 01:23 AM
CRXsiZCpa's Avatar
CRXsiZCpa CRXsiZCpa is offline
I never saw Sychromesh at any Auto Zone, Advance Auto, Pep Boys or any local auto store by my house. I always had to get it at the dealership. Lucas Trans Oil works wonders too.
Old 09-29-2004, 10:25 AM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
syncromesh is the shit, but like said above the local autoparts stores here don't carry the penzoil, so i have to go to GM and they charge an arm and a leg...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 09-30-2004, 07:18 AM
SiZ's Avatar
SiZ SiZ is offline
Welcome to 1st gen B16 trannys.
They all grind at least third gear, get used to it.
Mine grinds every gear.
Old 10-01-2004, 03:19 PM
tenz0's Avatar
the thing is though, the first transmission i had only lasted a few months because it got stuck in 4th gear, then my 2nd tranny wouldnt go into gear at all less than a month after i put it in...and since the grinding moved from 3rd gear to 5th gear i think if i adjust the clutch cable even more it shouldnt grind at all...but maybe im wrong
i guess part of my question should actually be: Could the adjustment of the clutch cable have anything to do with my transmission grinding a gear?
http://ef-honda.com
-my hatch
Old 10-01-2004, 03:21 PM
Forunn Daberator
yeah it has alot to do with it, if there is too much slack it will grind, Keep adjusting till you get it where it grinds the very least, or not at all.
