Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 09-27-2004, 10:49 PM
95luder 95luder is offline
Send a message via AIM to 95luder
Question knocking noise when turning
I'm having a new problem with my lude, and I wanted to know if anyone has had this problem. When I parked today I had turned the wheel so my wheels would be straight, and I heard a grinding/knocking/crunching noise. I thought maybe the wheels were perched on a rock or something, so I backed up and tried again, and it still made the same noise. From the wheels being straight, turning the wheel one quarter of a turn either way makes this noise. Any insight and help is appreciated.
Old 09-27-2004, 11:27 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
Check your CV Boots
Old 10-15-2004, 11:44 AM
93/01alaLUDE 93/01alaLUDE is offline
Does same sound exist when you turn when car is moving? I never noticed the noise when sitting still but when moving same sound occuried and i had to get new front axles
Old 10-14-2006, 03:27 AM
negative123 negative123 is offline
Re: knocking noise when turning
my lude does the same thing, and i just bought new tie rods and cv boots. If those don't do the trick, i'll just gonna go with buying new driveshafts (cv joints) but when i install the new rods and boots, ill let you know if that was the case. the way you describe the noise, sounds exactly like mine, so.....
