Old 09-27-2004, 09:25 PM
jacosta99 jacosta99 is offline
89 turbo-- help
I have an 89 turbo trans am. I have done a complete tune up. Everything was replaced. I'm getting a high idle of 1500 rpm at dead stop. The car wants to burn rubber by itself. I need to know how to get the idle back to 500 rpm like it should be.
Is there any suggestions?
Old 09-28-2004, 05:22 PM
86TATpi 86TATpi is offline
Did you do anything with the IAC?
Old 09-29-2004, 08:40 PM
Re: 89 turbo-- help
Can you be more specific. Is that the idle air control sensor. If so, what do I do to check it. I am not a mechanic.
Old 09-30-2004, 01:11 PM
The idle air control valve is on the throttle body, it has a pintle that moves in and out to adjust for throttle position to allow air into the car to keep it running at closed throttle. If it is bad or somehow was misadjusted the idle may not be good. Also check for a loose or disconnected vacuum line.
Old 10-03-2004, 08:49 AM
cndctrdj cndctrdj is offline
Send a message via AIM to cndctrdj
Re: 89 turbo-- help
most of the time the iac is just dirty clean it with a qtip and see if it helps
95 TA - fast
92 240 - fun
96 prelude si - lots o fun
94 cr500r - rediculously fast and fun
