Old 09-27-2004, 08:58 PM
BlackEclipse97 BlackEclipse97 is offline
Banned
Send a message via AIM to BlackEclipse97
Question clicking clutch
what is wrong with my clutch if when i push it down it makes a little clicking noise? but when i let off of it it stops. The clutch its self works perfect
Old 09-27-2004, 09:04 PM
joemathews's Avatar
joemathews joemathews is offline
Re: clicking clutch
How loud is the clicking noise? A soft creaking in the clutch can be normal, if it is difficult to hear. A loud clicking noise may indicate a problem--perhaps something to do with an imperfection in the mating surface between the clutch plate and the flywheel.
1996 Eagle Talon
Old 09-27-2004, 09:07 PM
Banned
Re: clicking clutch
its not real loud but i can hear it i dont have to listen real close, i can hear it a little bit in side the car
Old 09-27-2004, 09:13 PM
pro3racer pro3racer is offline
is it just one click, or many? i believe it may be that little sensor thing, that makes a click when the clutch is pressed almost all the way down? Just a possiblity?
Old 09-27-2004, 09:28 PM
Banned
Re: clicking clutch
many, what sensor thing are you talking about? is it suppose to do that?
Old 09-27-2004, 09:35 PM
oh, then nevermind, if it was just one click, then i would say it was the sensor, that makes sure you have the clutch depressed, while starting the car. Nevermind then, this isn't my area really.
Old 09-27-2004, 09:36 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: clicking clutch
does it change with engine rpm?
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 09-27-2004, 09:42 PM
Banned
Re: clicking clutch
im not sure but i think it might like it clicks faster i think
Old 09-27-2004, 10:03 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: clicking clutch
When you're driving and you turn the wheel all the way to the left and press in the clutch, does it stick any (as in stay on the floor)? If so, it may not be good.
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 09-27-2004, 10:05 PM
Banned
Re: clicking clutch
i dont think so but if it does what does that mean?
Old 09-27-2004, 10:13 PM
Re: clicking clutch
I shant say the word, because it has been banished from these forums forever! Naw, just because your clutch clicks doesn't mean it's crankwalk, because there are a good many other things that can cause the clicking noise. However, a clutch that clicks when depressed, and a sticking clutch when making a left turn are symptoms of crankwalk.
95 GSX
Old 09-27-2004, 10:23 PM
Banned
Re: clicking clutch
nope i just drove it and it doesnt stick when making a left hand turn THANK GOD!
Old 09-28-2004, 07:53 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: clicking clutch
Are you sure this click isn't coming from under the dash? Mine used to do that, but I used the fix that was posted when this question was addressed previously.
http://www.automotiveforums.com/vbul...t=clutch+pedal
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 09-28-2004, 08:29 AM
n8s95gsx n8s95gsx is offline
Same thing happend to me and i just got my car back with a $4000 bill. listen and see if the clicking noise is comming from the bottom right hand side of your engine. i have seen it 8 times now, all with this same "ticking" or clicking noise. the dreaded CRANKWALk.
Old 09-28-2004, 01:08 PM
Banned
Re: clicking clutch
right hand side if your looking at the front of the car or right hand side if you are sitting inside the car?
