I have a 98 caravan. On ours there was a fan relay that was defective. we never received the letter to have it replaced for free. From what I understand it it will either get stuck in the on positon or the off position. ours got stuck in the off position, so the car would get very hot even though the radiator was full and the thermostat was good. (fan was never coming on at the right time) sometimes we would stop and the fan would stay on (normal) but come out an hour later and still on (not normal). anyway its fairly cheap. its on the driver side engine compartment below the radiator. (weird spot) its about 2x2 inch from what i remember. hope this helps you.
Originally Posted by mledoux
I have a 1998 Plymouth Voyager with 105000 miles. Check engine soon light came on. Today on way home oil light and brake light came on as well. A couple of miles down the road all warning lights went out. A couple of more miles they came back on. When I arrived home aroung 6pm the fan stayed on after turning van off. (first time this ever happened) A little while ago around 8:45pm went outside and fan motor is still running. Can anyone advise what the issue could be? I recently had the oil changed and I have checked the coolent and all looks good. The van is running ok just started freaking out. Any help would be great....Thanks
