Help! Turn signal gone berserk!
I have a problem in my 95 Windstar. Occasionally, the rignt interior turn signal goes crazy and blinks rapidly when it is activated, sounding like a machine gun. I dont think the exterior signal does the same.
Can anyone tell me how I can repair this? Thanks. |
Re: Help! Turn signal gone berserk!
Check the exterior lamps to be sure. If one exterior lamp is out, the blinking speeds up quite a bit on most older systems.
When our Sable's turn signal goes nuts it means the bulb is blown. Replace the bulb, it will stop.
I think in older cars there isn't a dash light to let you know. When older models were made a very fast 'blinking' turn signal on the dash was the indicator for burned out bulb. |
don't feel bad if it is the T/S assembly (aka Multi Function Switch). The Ford parts are typically under $100. I just replaced one in a '99 GMC P/U Thursday, OUR discounted cost was $254!!!!! List was over $300. Oh, on the GMs, you HAVE to remove the steering wheel. 2.5 hr flat rate.
I've changed MFS is Fords in under 15 minutes, and as long as 30 minutes, so the 2.5 you were quoted was robbery. Check the lights first, if you don't find any faults there (they all work) and everything is flashing normally, wait until they flash rapidly THEN while they are acting up recheck the lights. You will know if it's wiring, the switch or the bulbs by wether or not all the lamps work. Also, what year is you WS? |
