Old 09-27-2004, 08:06 PM
DonRose DonRose is offline
Steering Column
My 91 S10 Blazer has a lot of vertical play in the steering column. You can set the adjustment but the wheel still move up almost an inch. So I believe I have problme in the column. The steering is fine. Does anyone have a diagram of what is in this column before I take it apart. I would like to know what I am in for before I get started.
Thanks for any help
Old 09-27-2004, 08:26 PM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
Re: Steering Column
that happened to our 91 full size chevy pickup...and well...what i would do if it was you...just take it apart...carefully...and just figure out how it goes together...lol...although that isn't probably what you wanted (but i don't remember what we fixed in the steering column to remedy that problem)
Old 09-27-2004, 09:09 PM
Mikado14 Mikado14 is offline
Re: Steering Column
Sounds like your tilt bushings are worn or loose. Been a while, (a year or so) since I had one apart, but as the previous fellow told you, carefully take the column apart and see where the play is at.
Old 09-28-2004, 12:28 PM
Thanks for the replyies. I guess there is little in the way of information on tilt steering columns.
Old 09-28-2004, 01:59 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Re: Steering Column
^What he said.
Old 09-28-2004, 02:23 PM
Re: Steering Column
Have you ever tried looking in something like a Chilton's book...Your public library would probably have one if you don't
Old 10-06-2004, 09:45 PM
Walker S-10 Walker S-10 is offline
Re: Steering Column
there are four screws in the column i just did this a mouth ago you got take it all apart to put them back in make sure you use lock tight and if you don't fix it the colum will come apart this is a very hard job to do
Walker
