Go Back   Automotive Forums Car Chat > Lincoln > Mark VIII
Old 09-27-2004, 05:21 PM
xdrivex xdrivex is offline
CD player CD Changer question
Guys , i'm posting this message on here hoping on of you have experienced a similar situation .
I just bought this Lincoln Mark VIII 1998 and on the CD display i can see the CD buttom but not CD slot and no CD changer anhywhere in the car not in the trunk and not under the seat .
When i press the CD button it says NO DJ , i looked this message up and basicly what it said is that no CD changer connected .
can i just buy the CD changer and hook it up ?
is there alot of wireing need to be done ?>
is it a remote control CD changer ?
any inputs is appreciated
Old 10-15-2007, 09:45 AM
islandgirl64 islandgirl64 is offline
Re: CD player CD Changer question
I have exactly the same situation. I too just bought a '98 Mk VIII with no remote CD changer although it has the installed JBL radio for one, and would apprecite an advice as to installing the changer.
Old 11-18-2007, 07:45 PM
BlackiceLSC BlackiceLSC is offline
one of two things have happened.
either the original radio was replaced with another one somewhere along the lines, and the car never came with a CD changer
or
the trunk mounted CD changer has been removed. If the car came with a CD changer, you need to check the driver's side rear corner of the trunk. Lift up the carpet and look for the harness.
The ON/OFF buttons on these radios are a commonly failing part(they wont turn off the radio when depressed) so many past owners replaced them since all 1995-1998 stereos are a direct plug and play. However, if your car never came with a CD changer in the trunk, then the CD option on your head unit is useless.
