Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 09-27-2004, 04:21 PM
neo the hacker neo the hacker is offline
smokey engine
Can anything be done at all with the 944 engine? its smokey, and i know number 3 cylinder is a bit worn, i know there's not a lot can be done with them because of the cylinder liners, but surely somebody knows something. its an 88 with 137,000m/ph 0n the clock. thanks
Old 09-27-2004, 09:49 PM
930guy 930guy is offline
Re: smokey engine
Are you sure its not valve seals or worn valve guides?
Old 09-28-2004, 02:40 AM
Re: smokey engine
Ive not long done a headgasket, and i fitted a full headset, so its had new valve stem seals, not sure on the guides but there wasn't any play in them. when i stripped the head down, no3 cyl was scored but it wasn't smoking before i did the job?
Old 11-01-2004, 08:45 PM
Great-King-Rat Great-King-Rat is offline
Send a message via MSN to Great-King-Rat
are you sure its not burning oil?
Old 11-02-2004, 02:37 AM
Re: smokey engine
yes it is burning oil, hence the smokey part. Because ive done the head it now as lots of good power and a lot more pressure, but its resulted in pulling a bit more oil past no3 cylinder rings. The car as loads of power and sounds fantastic with the new s/steel exhaust but when when its hot, its putting a bit more blue smoke out than i would like.
Old 11-05-2004, 02:10 PM
busa_4 busa_4 is offline
Re: smokey engine
take it to a good reputable machine shop when your ready to dissassemble it and rebuild the lower end. they can resleeve the cylinders. they are hard to resleeve so make sure you go to a reputable mechanist.
Old 11-05-2004, 06:51 PM
eohrnberger eohrnberger is offline
Send a message via Yahoo to eohrnberger
Re: smokey engine
Ouch. That sounds like some really big bucks. I sure hope that it'll turn out OK for you.
Best wishes,
Erik.
2002 GT Purchased new, Loaded with options Mud Flaps, Michelin HydroEdge, U-Bend Replacement, GMPP Handling Kit, ZZP Strut Tower Brackets
1991 Porsche 944-S2 with 175,000 Miles (and counting)
Old 11-06-2004, 05:34 AM
Re: smokey engine
I think i'll drop a short motor in it, i've just got a low mileage one come in so i'll use that one.
Old 11-07-2004, 11:46 AM
cv53hts cv53hts is offline
Re: smokey engine
Hello:
I have a 1986 944 Turbo sitting in the garage for
the last 3 years. I took it out last month, it leaked
oil somewhere above the manifold area, and give white smoke. It stopped when it got warmed up.
I drove it for a week. Now, it takes longer to stop
smoking. What is needed ? Thanks !
Old 11-07-2004, 02:36 PM
Brighton_Rock_NCC Brighton_Rock_NCC is offline
Well youve basically got a pretty nasty oil leak and the white smoke is the oil burning...so all you can do is find the leak and try to prevent it. How many miles are on the engine?
Neo the Hacker...hows it coming with yours?
Old 11-07-2004, 04:58 PM
Re: smokey engine
CV53, like he said, what mileage as it done?. Not got around to doing the engine yet, its not that bad. Just done gearbox so i'll be posting pics of my toothless insides of the old box.
