Old 09-27-2004, 04:10 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
1995 grand prix gt descides when to start
sometimes it will start and other times it wont, it will turn over fine... but what could cause a car to stop starting.... i can drive it for an hr and then park it and it wont start again, just turn over...
Old 09-27-2004, 07:27 PM
lineguy lineguy is offline
Re: 1995 grand prix gt descides when to start
I had a 92 with the same problem. I replaced the ignition module and it fixed the problem.
Old 09-27-2004, 08:12 PM
EDMUND65's Avatar
how much do those run, and is that something i can get from a junk yard? would you have a pic of one?
Old 09-27-2004, 09:54 PM
GirlInAHotRod GirlInAHotRod is offline
Send a message via AIM to GirlInAHotRod Send a message via Yahoo to GirlInAHotRod
They are like 90 bucks for a Grand Prix at autozone. Be sure that's what it is before you replace it. You can always take it to a garage to find out, some places will check a car for free, just have to call around.
Old 09-27-2004, 10:21 PM
EDMUND65's Avatar
oh, ok thanks!!! but is there anything else, like i said it will drive around and then park and not start... u know?
Old 09-28-2004, 11:19 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I would check the crank sensor first. Much cheaper and easier to replace. It's a common problem on 3.1's When the car doesn't start, are you getting spark? If not, try a crank sensor first.
Old 09-28-2004, 11:33 AM
EDMUND65's Avatar
it will crank and i get spark, but its a 3.4
Old 09-30-2004, 01:52 PM
GTPWarrior's Avatar
GTPWarrior GTPWarrior is offline
I would agree with tazz on this one I would check you CPS first it is alot cheaper and I had very similiar problems and if it is the CPS it will soon decide to not start at all. That is were I am sitting with mine (3.8L)
Old 09-30-2004, 03:02 PM
EDMUND65's Avatar
how woudl you get it tested? what do you need to take off it?
Old 09-30-2004, 03:57 PM
BIG-L's Avatar
BIG-L BIG-L is offline
Most of the guys at the GM service center,forget about the CPS failing and there is really no way THAT I KNOW to test it and 99% of the time it wount set an SES.Here is a pic of what it looks like and its behind the harmonic balancer.
Pic of Ignition control module and they arent cheap,$117.35 from GMPartsdirect.com and list price from dealer is $234.70.Your coil packs sit on top of it.
ClubGP Member 6530
Since 2001
Old 09-30-2004, 05:18 PM
EDMUND65's Avatar
ouch... how bout a junk yard?
Old 09-30-2004, 05:37 PM
BIG-L's Avatar
I agree with rich.Id try the CPS first since it is the cheaper of the 2 and for your car they cost 23.47 = shipping thru www.gmpartsdirect and dealer cost is $46.94 or call around at some of your local auto parts stores and ask for a Crankshaft Position Sensor and see what they cost.Then if that dosent do it you may try some salvage yards for the other part.
~Larry~
ClubGP Member 6530
Since 2001
