Go Back   Automotive Forums Car Chat > Mitsubishi > Mirage
Old 09-27-2004, 03:58 PM
galantsucks galantsucks is offline
Send a message via AIM to galantsucks Send a message via Yahoo to galantsucks
Question Questions on 1997 Mitsubishi mirage
Hi
I am planning to buy a 1997 Mitsubishi Mirage with Auto transmission. But the car has 2 problems.
First problem is that the "Check engine" light is ON. The current owner is saying that the problem is bcos of the Exhaust gas recirculation (EGR) valve and it has to be replaced. My question is that, could that be the only reason why u could have "Check engine" light ON.
Second problem is that the when the car shifts gear internally, u can feel the jerk in the transmission. Is it normal for these cars or is it a sign of impending failure.
Thank you,
Old 09-27-2004, 09:41 PM
gooseman1 gooseman1 is offline
Re: Questions on 1997 Mitsubishi mirage
first question:
Try resetting the ECU by removing the ECU fuse... the 40amp fuse in the engine bay and reinstall that ECU after about 10 sec.. This hopefully will clear all errors saved in the ECU.
Question 2:
When the car changes gear, what is the rpm and which gear was it? normally it would not jerk.
Old 09-29-2004, 02:31 PM
bestkept's Avatar
bestkept bestkept is offline
Send a message via AIM to bestkept
Yo
I drive a 97 mirage de automatic and im the worlds biggest led foot. if im all over the gas my tranny slams too. the check engine light could be a few things, like when i put my subs in i disconnected my battery and that made my light come on until the car reset the diagnostics. there are a lot of things. my best advice is to take it to mitsu and have them look at it but thats expensive.
