| Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security. |
another ohm ?
what is the difference in characteristics if a sub is say single 2ohm, or single 4ohm, then to a double 2ohm or double 4ohm sub? what does it change in the sub? why would they make 8ohm subs if its gunna take a higher output amp to power them? and also, if an amp is hooked up to a single 4ohm sub, then hooked up to a double 4ohm sub, will the amps power be split? thanx 4 ne input
Re: another ohm ?
well... make an 8 ohm sub so you can slap more together
. There is no difference between different ohm subs
www.cloudcity.deviantart.com |
Re: another ohm ?
the difference is the wiring options, that's all
and like Haibane said, 8ohm subs are made so you can run them on a home theater stereo, or you can run 8 of them in parallel to a 1ohm stable amp in your car.
'01 Black Sentra SE Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8 '05 Silver WRX STi Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials |
