Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 06-01-2001, 10:44 PM
ptrkng ptrkng is offline
Rewiring Corner Light on 95 max
i know you can rewire the corner lights on 97+ max
but are there any ways you can rewire the corner lights
on 95 max...
thanks
Old 06-04-2001, 08:40 AM
punabuds punabuds is offline
Send a message via AIM to punabuds
I did a temporary rewire of my corners so that they indicated and the bumpers stayed on the whole time. Made it a little hard for people to see me indicate during the day with the polarg bulbs in them so I switched it back. Other than rewiring you could clip the knob on the bulb, put it in backwards and then your corner will run bright the whole time.
I can only dream of a tight ride...
Old 06-05-2001, 09:13 PM
rewiring corners
can you explain with some more details....
thanks
Old 06-12-2001, 01:47 PM
ThA_KwAK ThA_KwAK is offline
Lightbulb I SUCCESSFULLY REWIRED THE 95 GLE CORNER LIGHTS
Alrighty..
My name is Young Kwak (funky name..i know!!!) and I can help all of you out there with a 95-96 max...
I successfully rewired the corner lights on my 95 GLE.
I HOPE Cheston will POST this in his how to...
Ok,
First off, you'll need
-Screwdriver (both Kinds)
-Soldering Iron (careful...i burned myself and a blister formed for 5 days)
-med gauge solder
-something to hold things with (like tweezer or CHOPSTIX)
-Immunity to BURNS
Now...remember that this is DC current and if you mess up then a fuse or wiring harness is buh-bye
1) You need to remove the corner lamps.
To do this, You need to first start by removing the screws that hold the Lamps (they are under the Hood Lid). After that, you need to work the lamps out of the sockets. If you pull hard enough (not too hard) you will be able to see something like a stick that goes into the car frame next to the Headlamp housing.
To get that "stick" (a ball and socket thingy) out, you should try to squeeze a flat head screwdriver right into the end where it connects and pull the lamp while twisting the screwdriver. Do this with enough pressure and It will POP! out. Then, just disconnect
the the power.
2) Now you need to take it all apart...YAY
If i remeber correctly (doing this from memory while refusing to do my NSI data bulllcrap at the office), you need to take out the bulb harness and then the bulb...they TWIST out. Now look at where the two ends of the bulb touched the harness. It should be a small black circular plate with 2 small metal circles. If you get a small flat head, you should be able to work the plate out. You have to kinda twist and push and pull (man...). To make it a lil easier, you can PUSH UP (with a pen or something of that size) the tiny rubber part on the backend of the harness where 2 wires go in. If there is a balck wire covering over the 2 wires, you are gonna hve to remove about 2 inches of it so yo ucan push the wires up. One the wires are pushed up and the black plate is pushed out, you are gonna have to create about 2 inches of slack to work with. Also, dont lose the spring, but keep it in the cylindrical casing.
3) Sorry so long...Now you have to start soldering.
It will help if you have the soldering iron already heated up. Ok now. You need to separate the black and red wires from the Plate. To do this you need to heat(with the soldering iron) the metal dot/connection thingies while pulling the wires from the plate (this will take some dexterity). REMEBER WHICH WAY THE WIRES WERE COMPARED TO THE PLATE. After you do this, you need to switch the wires around (this means the black wire will go where the red wire was and vice-versa). "I think the black wire is the one that is supposed to be closest to the rectangular protrusion from the circle plate." To reconnect the wires, you need to heat the metal dot thingies from the one side while pushing the exposed wiring through to the other so that the wire is fully in the dot thingies (if you just solder the wire to the dot thingies, it WILL break apart). Do this to both wires. To make the soldering a lil more secure, you can place some solder over the dot thingies on the side facing the spring.
4) Put the plates back in the housing.
This can be a lil tricky. If you look at the cylindrical housing of where the black plate and bulb go in, you will be able to see a small rectangular opening towards the base. It is in this opening in which the protrusion from the circular plate will enter. While keeping this in mind, you need to place the plates back into the harness as it was before. While placing the plates back in, you also need to pull the wires from the backend in order to prevent slack from keeping the plate from going in.
5) Testing it out...
With all this done, just put th ebulb back in and put the bulb harness back into the corner lamp housing. Connect the power cable back into the Corner lamps and test it out before putting it all together. Now, if done correctly, the corner lights should be running the 27watt filament wether or not you blinker are on.
GOOD LUCK GUYS, and if anyone has any question about Electrical stuff in a maxima, email me at [email protected]. Or message me thru my AIM name, YKwak11484
