Old 09-27-2004, 02:51 PM
chvyguy chvyguy is offline
Unhappy Fuel Gauge
Thanks Again To Matt For Help With My Last Post. I Have What Seems To Be The Standard Chevy Gas Gauge Gremlin Its Always Above 1/2 Tank And Sometimes Never Goes Below Full. Heres The Thing That Makes Mine Different If You Tap The Gauge The Reading Will Change By 1/4 To 3/8 But It Still Never Goes Below Half Even If Its Bone Dry. Any Info Would Help.
Thanks In Advance.
Old 09-28-2004, 01:36 PM
bigdaddyviking67 bigdaddyviking67 is offline
Crazy Fuel Gauge
I have the same problem with my 1994 Z71. I replaced my fuel sending unit and after I did that, my fuel gauge has been posessed. It will go way past the F when I fill up the tank and when its empty it will usually sit around the 1/2 mark. But there have been times that it goes down to empty. I can't trust that bastard at all, I ran out of gas at 1/2 full once, so I don't go by it anymore. If you have replaced the sending unit, it is possible that the float arm got bent or was bent on the new unit. when I pull mine out the next time during the unavoidable fuel pump change, I am going to bend my float arm a little to try and compensate for its inaccuracies.
Old 09-29-2004, 03:29 PM
Blue_Villain Blue_Villain is offline
I stopped even looking at mine a long while back. Now I just go by the miles...
I know that under normal driving I get about 12 mpg... and on a 31 gallon tank that's 372 miles... I normally try to get gas at around 300 miles just to be safe (fuel sending unit probs and all).
Now if I only had a resetable trip odometer...
Just my $0.02
-Villain
Old 12-09-2004, 12:36 PM
rgloston rgloston is offline
Re: Fuel Gauge
I realize that this thread is old, but have any of you thought once that the gauge cold be bad. I have an '86 Silverado (262ci 4.3L V6), and have had that gauge go bad on me after ten years of owning the truck.
What happened to me was:
full-tank read 1/4 tank on gauge
half-tank read 1/8 tank on gauge
empty read just plain EMPTY
With my truck, changed gauge (dealer part), and reads properly everytime. Of course, est by mileage is a great habit.
-R.G. (Baton Rouge, LA)
1986 Chevy Silverado (SWB - Black) (262ci 4.3L V6)
Old 12-09-2004, 01:14 PM
Re: Re: Fuel Gauge
Never thought of that, is the fuel gage a seperate part that some how gets pluged into the back of the instument panel or is the unit one whole thing?
Old 12-10-2004, 01:11 PM
klt klt is offline
At least I don't feel alone now. Mine went out ages ago. Tried to follow some directions about resetting by manually pushing the pointer back to E but no good. I always fill up and reset the trip odometer. Added advantage is that I always know the miles per gallon. If anyone finds the answer please post. 2 kids in college and too tight to fix something expensive that I can live without. My vehicle is a '97 Astro van.
Old 12-11-2004, 05:50 AM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Fuel Gauge
Thanks In Advance.
Try taking the guage out and cleaning the terminals on the back really good. Looking at a wiring diagram for my '86, the center terminal is probably very loose or corroded.
Old 12-21-2004, 01:40 PM
Re: Fuel Gauge
Sorry for the late response...
Yes, mine is a seperate part that has electrical leads that plug in the back side of the gauge. I checked wires & terminals, but saw no physical abnormalities. I replaced that years ago, and all is still great. Believe it or not, I remember a GM service tech recommended that, and what do you know... he was right.
______________________________________
*bigdaddyviking67 *
