Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 02-13-2002, 04:43 PM
G20ps G20ps is offline
rod bearings, turbo rebuild?
I am buying a Bluebird SR20DET with only 12,000 miles on it in very good shape from a reputable seller. I was wondering this: would you think that I should still replace the rod bearings, and possibly rebuild the turbo, as it has such low miles? I am replacing the waterpump and probably main seals regardless, but what do you guys think?
Old 02-13-2002, 09:59 PM
P10DET's Avatar
P10DET P10DET is offline
Re: rod bearings, turbo rebuild?
Definitely replace the rod bearings.
Check the turbo for shaft end play. There should be none. If there is barely (I mean barely) detectable end play, you may want to get it rebuilt. If there is very detectable end play, don't even install it in the car. Get it rebuilt.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Are pistons & rods interchangeable when rebuilding '95 3.8 engine? J Parks Bonneville 0 04-29-2010 09:32 PM
rod bearing/bottom end rebuild csartoris Tiburon | Tuscani 0 02-21-2010 09:57 AM
ROD BEARINGS has anybody tried? Chuckmonster Caravan | Voyager 1 07-27-2009 07:50 PM
96 Knocking. Rod, rod bearing or piston??? swiesner Blazer 4 02-08-2006 08:19 PM
Hi, I have a 99' 3.5 with rod knock 29k can you replace rod bearings in car? jimg300 Intrigue 1 11-11-2003 09:28 PM
