Old 09-27-2004, 01:28 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
check engine light
went down to schuck auto supplys and had my codes checked, and it came out with p1104 manufacture specific powertrain trouble code. so i called my local mitsu dealer and had them pull the #, they told me it was my wastegate actuater malfunction code. figures. i installed a MBC last month, the code did come on the same day. is this detrimental to the car? when i installed the MBC i disconected the boost controlle sylinoid and threw it in the "stock parts box". i'd emagin thats whats freaking the computer out, i doubt its a big problem, but i wanted to ask.
DSM geek
Old 09-28-2004, 10:38 AM
gsxygirl gsxygirl is offline
Send a message via AIM to gsxygirl
Re: check engine light
I hate check engine lights so much..mine will not go away..we ran the codes and found out it was misfire #3..fixed that then cleared the codes, i drove the car atleast 200 miles to reset certain codes so i could go get it inspected, and it still didn't fix the damn problem...ugh i dont know what else to do with it
Lindsey
-98' eclipse gsx
Old 09-28-2004, 11:49 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Plug the BCS back in
Lindsey, are you saying the problem is still there, the code is still there, or you just can't get emissions?
Old 09-28-2004, 04:04 PM
tsi95 tsi95 is offline
my check engine light wont go away either. we gound out it was the IAC and replaced it. it was running fine for about a week and then the check enginge light came back on again.
Old 09-28-2004, 07:40 PM
RiceRocket18's Avatar
RiceRocket18 RiceRocket18 is offline
Send a message via AIM to RiceRocket18
did you pull the code again this time? what is it?.. is it the same code as before ?
06 Charger SRT-8 black.
Old 09-28-2004, 08:25 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
damn CEL's... everything i have done and i have never once seen a CEL.
Old 09-28-2004, 08:44 PM
george536's Avatar
george536 george536 is offline
Re: Re: check engine light
maybe you cel is broken. nah juss playin not trying to jynx you. lol
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 09-28-2004, 08:47 PM
jeez you are right... probably should not have said that...
Old 09-28-2004, 08:51 PM
george536's Avatar
lol it was probably on soo much before it juss burnt out.
j/p. your probably juss lucky........ i think
-1990 Eclipse GSX
Old 09-29-2004, 04:09 AM
kjewer1 kjewer1 is offline
AF - Advisor
I think what lindsey is saying is after resetting the ECU the CEL came back. Usually when you get single cylinder misfires you cant feel it. If its a stutter you can notice it always seems to come up as Random Misfire. I could be wrong. At any rate after setting the ready flags in the ECU to get ready for emissions testing (OBD2 readiness checks) the CEL came back I assume. What did you do to fix the cyl3 misfire Lindsey? Based on the wording it sounds like you did something. Plugs and wires typically do it. I Would check the code again either way and see if its the same cylinder. If you get single cylinder misfire codes in randomly different cylinders, I wonder if that couldnt be a bad CAS. Who knows. Get it read and see if its still number 3, if you havent already.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-29-2004, 07:37 AM
real_madridcf's Avatar
real_madridcf real_madridcf is offline
Send a message via AIM to real_madridcf Send a message via MSN to real_madridcf Send a message via Yahoo to real_madridcf
My damn CEL is always on, all the time. I fix the prob then like 2 days later the CEL comes back on. My car is spoiled; always whining! lol
95 Eclipse GS: OBX Full Exhaust System, OBX Headers, OBX Short shifter, OBX Spark Plugs & Wires, 17' MSR Rims w/ Wanli tires
96 Eclipse GS-T : K&N Filter w/ Hardpipe, UICP & LICP, Greddy Type S bov, Greddy Boost Gauge
Hala Madrid!
