| B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version. |
need help
91 b2200fi and what kind of problem do you get with a ecu going out becuse my truck run but with a lot of black smoke coming out of the tailpipe
Re: need help
black smoke mean running to rich ck fuel pressure and pressure regulator also see if any codes in computer also check o2 sensor and coolant temp sensor
Re: need help
if what bfg2200 says is all ok then if the ecu is suspected i would check you 5 volt reference signal from ecu i usually check at temp sensor not gauge driver on tstat housing the one under your intake rec looking at etm for correct pin
