Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 09-27-2004, 12:31 PM
simpelli simpelli is offline
Strange Electrical - 87 Ram 150
Greetings,
I'm in the process of restoring an 87 Ram 150 LE short box. (First project like this) So far, mechanical and body work has gone well, but I ran into a strange problem with the brake lights.
They come on normally with the headlights off. When headlights are on, running lights appear as they should, but when I hit the brakes, the tail lights go out instead of getting brighter. I've probed the harness at the end of the run (just before the tail light wiring assembly) and it operates correctly with the tail light assembly unplugged. Also, if one or the other tail assembly is disconnected (left or right) the opposite one works correctly, but not when both are plugged in.
No broken wires on either assembly.
Any thoughts?
Thanks
Old 09-27-2004, 01:15 PM
crazy cajun's Avatar
crazy cajun crazy cajun is offline
Re: Strange Electrical - 87 Ram 150
has to be grounding out somewere when brakes are applied
crazy cajun
1997 Dodge ram 1500 V-8
1980 Yamaha XS850SG Special
Old 09-27-2004, 01:53 PM
Yeah, thought of that.
How would you trace that kind of thing? Start at the switch? What do I look for?
Old 09-27-2004, 02:16 PM
i would start in the back at the lights look for a wire that has a cut or been smashed and is missing some of the coating its like finding a needle in a haystack.
crazy cajun
Old 09-27-2004, 11:21 PM
sleepygene62 sleepygene62 is offline
check the tailight assembly it self for ground, if you have the ground end of the test light on the taillight socket you should get ground, if not run a wire from the frame to the socket or track down the factory ground in the harness, a bad ground will do crazy things sometimes.
