I have a 1998 Contour SVT. After a very short time in the car there is a smoking problem that seems to come from the glovebox and out of the vents. The temperature gauge is fine. The oil is fine. I think something electrical may be burning. I have opened the hood and couldn't determine the problem. What can this be? The smoking doesn't effect the driving of the car. What should i do?
It is most likely your factory amp for premium sound. Ford puts the amp right behind the glove box. There are 2 screws under the glove box to remove it, take them out and lower the glove box, then just check it out. See what's smoking.
Re: 1998 Contour smoking from glovebox
Thank you so much. I will try that this evening after work.
Just wanted to let you know that I did attempt to remove the glove compartment and I've had no luck. I've re-read your post and I see what I was doing wrong. I'll try again and report back.
Alright, if you need any further help just ask. I've done it before and im good with electrical. :P
