Old 09-27-2004, 10:58 AM
genie45 genie45 is offline
Angry changing headlamps 95 Windstar
I was hoping someone out there had experience at changing headlamps, I haven't the foggiest idea what to do first. Mine are getting water inside and I know they must be changed before it gets cold here as I live in Michigan. Thanks so much for your help!!
Old 09-27-2004, 07:47 PM
DRW1000 DRW1000 is offline
Re: changing headlamps 95 Windstar
Are they the same as a 99?
Where is the water? Surely you have a bulb inside a lens assembly? If this is the case then I am not sure if replacing the bulbs will solve your water problem. The bulb replacement precedure is in the owners manual. It will allow you to remove the entire assembly.
