Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 09-27-2004, 09:30 AM
vobraman vobraman is offline
towing capacity
I have a 1999 Sub and wonder how much I can tow ? I have read what is in the manual, however I like real life stories. I want to get a 22 or 24ft enclosed car hauler. Has anyone done this and if so what else did you change. For eg., rear suspension, anti-sway bars. Just looking for info.
thanks
Old 09-27-2004, 09:45 AM
Rbraczyk Rbraczyk is offline
Send a message via AIM to Rbraczyk
Re: towing capacity
Your max is probably in the vicinity of 8-10,000 pounds. You need brakes for the trailer, and a few other things. You may also need load bearing springs in the back.
Old 09-28-2004, 11:00 AM
Pamsdad Pamsdad is offline
The owners manual should be followed closely.
But if you're looking for 'Real Life Stories', you need to be more specific.
5.7 or 7.4?
1500 or 2500?
2wd or 4wd?
97 Chevrolet CC Dually
00 Blazer
Old 09-29-2004, 11:46 AM
Oh Yea. One more question.
Rear Gear. 3:42, 3:73, or 4:10. Assuming stock sized tires.
Yes. Everything matters. A 4wd 5.7 1500 3:42 equipped Sub will tow substantially less than a 2wd 7.4 2500 4:10. Maybe as much as 3k.
00 Blazer
Old 09-29-2004, 04:57 PM
5.7, 3.42 rear end, stock wheels
thanks
Old 09-30-2004, 10:49 PM
Larry Derouin Larry Derouin is offline
According to the Manual for the 99
C-1500 (2WD) SUBURBAN
Engine Rear Max Trlr Wt.
5.7L 3.42 5,500#
3.73 6,500#
6.5L(Diesel) 3.42 5,500#
K-1500 (4WD) SUBURBAN
5.7L 3.42 5,000#
3.73 6,000#
6.5L(Diesel) 3.42 5,000#
C-2500 (2WD)
5.7L 3.73 6,000#
4.10 7,500#
6.5L (Diesel) 3.73 6,500#
4.10 8,000#
7.4L (BIG BLOCK) 3.73 8,500#
4.10 10,000#
K-2500 (4WD)
5.7L 4.10 7,000#
6.5L (Diesel) 3.73 6,000#
4.10 7,500#
7.4L (BIG BLOCK) 3.73 8,000#
4.10 10,000#
Hope this clear up things.
Larry
