Old 09-27-2004, 09:22 AM
Musashi3000GT's Avatar
Musashi3000GT Musashi3000GT is offline
Swapping brake callipers.
Has anyone here swapped the brake callipers from the VR-4 to a base or SL? can it be done?
Old 09-27-2004, 10:22 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
There are some guys on 3SI who have done it successfully. do a search there. here's just a few:
http://www.3si.org/forum/showthread....light=calipers
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 09-28-2004, 05:27 AM
<T> <T> is offline
Re: Swapping brake callipers.
there's actually one product maker (forget his name) that makes adapters specifically for this purpose, although it still won't help you clear 17's or 16's.
