Old 09-27-2004, 12:33 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Angry Internet problem
Ok before I reformatted ( couple days ago ) any website would work, Now that I reformatted, Yahoo, Ebay and other site's just will not load. The security settings havent been touched, nor were they before. It's starting to piss me off, I can't check my email. Any ideas?
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 09-27-2004, 12:52 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
Re: Internet problem
Check your DNS settings, clear your cache and check for any software that would block them - even high security on cookies could do it.
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 09-27-2004, 01:00 AM
pre98zetec's Avatar
I've tried all of that, No luck.
-Josh-
Old 09-27-2004, 01:30 AM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
You've reformatted. All your network settings were erased during the reinstallation. Are you using dialup, DSL, or cable? Do you have a router? Are your TCP/IP settings correct? IP, primary and secondary DNS entries? Gateway IP? Is your PC always set to DHCP? Tried restarting your external modem or router if you have one? What OS are you using?
Just some suggestions to get you started.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 09-27-2004, 01:43 AM
pre98zetec's Avatar
I'm using DSL, And yes I have a router. I didnt set up anything because my router worked the second i reformatted. And I'm using XP.
-Josh-
Old 09-27-2004, 02:07 AM
Was XP hardcoded before you formatted or using DHCP? Did you manually enter the IP and DNS entries before? Are you unable to go to any websites or just those certain websites (eBay, Yahoo!, etc.)?
Old 09-27-2004, 03:25 AM
pre98zetec's Avatar
I reformatted again, Everything work's, I'm not using my router now. It's coming straight from the DSL modem and their software. I'll try the router
tomarrow.
-Josh-
Old 10-02-2004, 09:43 AM
pre98zetec's Avatar
well I reinstalled my router and it does it again, I don't know what the hell it's problem is but it only does it when the router is hooked up..
-Josh-
Old 10-06-2004, 09:59 PM
Probably a router problem. What brand router do you have? Do you have logging enabled on the router? Have you tried downloading the latest firmware for the router and flashing the ROM to see if it fixes the issue?
Old 10-07-2004, 08:16 PM
pre98zetec's Avatar
its a Network Everywhere 4 port DSL/Cable router.
I'll check and see if I need to update the drivers.
-Josh-
Old 10-07-2004, 08:42 PM
Give that a shot. Sometimes the router firmware can get flaky. Overwriting the existing firmware with an updated version will fix any firmware kinks and possbily improve the router's operation overall.
