Old 09-26-2004, 11:41 PM
alphalanos alphalanos is offline
amp went into prot. and never came out
i was messing around with my sub and after disconnecting the ground then reconnecting it, the amp went into protection. turned the car off for a while, check all conn. then tried agan...nothing. i have no idea what i did.
96 EJ6. Future home of boosted B18C1.
Old 09-26-2004, 11:45 PM
pac4eva5 pac4eva5 is offline
Re: amp went into prot. and never came out
probably blew a fuse. if u dont have back-ups, i got a pack of 5 at walmart today for $1.50
Old 09-27-2004, 11:59 AM
i replaced the fuse but it just keeps blowing out. all of the wires are the exact same way as they have always been. i dont know whats going on. i put the same type 15A fuse.
Old 09-27-2004, 12:06 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
you could have shorted the amp out
www.cloudcity.deviantart.com
jncodave jncodave is offline
sounds like your ground isnt solid
Old 09-27-2004, 12:10 PM
how can i test the connections? i have a voltmeter, what readings should i get?
Old 09-27-2004, 12:16 PM
Haibane's Avatar
well you should get about 12-14 volts on the power. and you should get 0 on the ground.
Old 09-27-2004, 06:01 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
yeah, its funny, but, if your amp blows fuses, there is something wrong. If you amp is in protection, and stays there, The amp is fried. What model amp is it? Wanna sell it?
Old 09-27-2004, 06:12 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
just because the amp goes into protection that doesn't mean it's fried....there are a ton of things that can cause an amp to go into protection without there being a single thing wrong with the amp.
Check the voltage at the power and remote terminals on the amp
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 09-27-2004, 06:30 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
my amp went into protection like that. it turned out to be a blown fuse on the power wire.
Old 09-28-2004, 03:11 PM
i checked the power wire fuse too; its fine. the amp doesnt get any power; or at least the power led doesnt light up when i have the system on.
Old 09-28-2004, 08:22 PM
sr20de4evr's Avatar
did you replace the fuse in the power wire or just look at it?
'01 Black Sentra SE
'05 Silver WRX STi
The Following User Says Thank You to sr20de4evr For This Useful Post:
crowtownsfinest82 (06-26-2012)
Old 09-28-2004, 08:23 PM
all i did was look at it...what are you implying? maybe its loose or otherwise broken?
Old 09-28-2004, 08:35 PM
ec437's Avatar
ec437 ec437 is offline
yeah you should replace it to see.
SoStAsSaId: and the flight attendant is cute... if i was a lesbian, i'd join the mile high club
<---call this number
The Following User Says Thank You to ec437 For This Useful Post:
Old 09-28-2004, 08:48 PM
sr20de4evr's Avatar
if it's an AGU fuse, the fuse itself can come detached from the end, it still looks normal from the outside, but it won't conduct anything. This has happened with 3 of my AGU fuses, I hate AGU....
'01 Black Sentra SE
'05 Silver WRX STi
