Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 09-26-2004, 10:38 PM
ViperJ's Avatar
ViperJ ViperJ is offline
Send a message via MSN to ViperJ
Rim Weight + Quater Mile Et's
I was just wondering if there is a formula for figuring out quarter mile time with different rims? Or maybe you can help with this, my car has stock 17lbs rims, the new ones I bought are 22 lbs any idea how much slower quarter mile time I will have?
White 07 STI, Bone stock for now
Old 09-27-2004, 07:28 AM
Alastor187 Alastor187 is offline
Re: Rim Weight + Quater Mile Et's
There is no simple formula to use because 1/4 mile times depends on a lot more variables than wheel weight alone. If you know what the other variables are then you could try to isolate the impact from wheel weight, but this not a simple process. In the end you would have done a lot of work for a very "rough" calculation.
The easiest and probably most accurate process would be to make several runs with both setups and compare the times.
