Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-26-2004, 09:42 PM
Allegretto's Avatar
Allegretto Allegretto is offline
Send a message via Yahoo to Allegretto
smoke and a stuck choke
more problems, need answers, my choke is now stuck open, and nowi got stinky white smoke, smog, whatever the heck it is spewing from my tailpipe, and it drips. somebody save me!
Old 09-30-2004, 08:27 PM
TommySS TommySS is offline
Re: smoke and a stuck choke
If you have stinky white smoke out of the tailpipe, you're dumping coolant (most likely a blown head gasket).
Check your oil to see if there's water in it.
Old 10-01-2004, 07:18 PM
Caprice Master Caprice Master is offline
U sure the choke is stuck open ? Or closed ? A closed choke can make white / blue smoke. Check the choke pulloff valve, maybe. Does the smoke go away after the engine warms up ?
Old 10-01-2004, 07:43 PM
A stuck choke would create black smoke (excessively rich mixture)
Old 10-05-2004, 07:49 PM
Re: Re: smoke and a stuck choke
Tommy,
Yes, I know that is the classic scenario, but when I had a rotted out choke pulloff valve, and my choke was stuck on (rich) for a few minutes after startup, until the electric choke took over, I was getting bluish white smoke, I kid you not. The mechanics were telling me it was worn out rings, and that I was burning oil, but it was the choke pulloff valve, in my case.
Caprice Master
Old 10-06-2004, 06:52 PM
Wow. I had the blue/white smoke at start-up since the car was a couple months old. Oil was getting into the chambers somehow but since it was minor, I left it alone.
I gotta check the choke pull-off.
Anyway, as Allegretto describes his problem, it looks like it could also be a blown head gasket. One of those can make a car look like it's an insect fogger.
Keep us in the loop and let us know what you find out.
Old 10-06-2004, 11:31 PM
burnM's Avatar
burnM burnM is offline
If you do have a bad head gasket, you may also have a higher idle speed. That could be why you think you have a choke problem. As Tommy SS stated, check your oil for traces of coolant, and check your coolant for traces of oil.
Let us know what you find...
1977 GMC Jimmy - daily driver-sitting on 33's and bedliner inside and out
1995 9C1 Caprice - winter beater
1994 Impala SS - newest project
1991 9C1 Caprice - (rip)
"There are two great problems in the world today; an ever-growing lack of common sense, and too many warning labels. Take away all of the warning labels and the problem will work itself out..." -B
