Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 02-13-2002, 02:49 PM
gally14 gally14 is offline
Send a message via ICQ to gally14
Valve Cover
How do you remove a valve cover for a 2002 G20. Is there a proper order? Also, how tight do thebolt/nut have to be when you replace the cover
Old 02-13-2002, 06:06 PM
Cue-Ball's Avatar
Cue-Ball Cue-Ball is offline
There is a proper order for both removal and installation, IIRC. Also, i think you have to tighten them to one spec, all in the right order, then go back and tighten them again, also in the right order.
Buy yourself a factory shop manual. That will tell you the exact order, and the exact tightness the bolts need to be.
1999 Infiniti G20t
17" RH Evolution M7000's with Toyo's
Mostly stock...for now.
Klaatu Varata Niktu
Old 02-14-2002, 02:58 PM
Does anybody have a service manual for a 2002/2001 g20?
Old 02-14-2002, 05:05 PM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
It should be the same between any of the G20's, as I don't think the valve cover bolt pattern changed at all. I don't have access to mine right now, otherwise i'd post it.
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 02-15-2002, 08:39 AM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
Code:
Remove the valve cover bolts in this order
11    4    8    6    9
1         13          2
10    3    7    5    12
Install with this pattern
11     6     2     4     8
12           1            9
13     7     3     5     10
STEP 1:  Tighten bolts 1 - 10 - 11 - 13 - 8 in that order
Step 2: Tighten bolts 1 - 13 in that order 8-10 Nm (0.8-1.0 kg-m, 69 - 87
in-lb)
Old 02-15-2002, 03:19 PM
Thanks G - Forces
Old 02-18-2002, 03:22 AM
ty423's Avatar
ty423 ty423 is offline
Send a message via AIM to ty423
Check this site out...this guys write up says alittle bit different but pretty much the same thing as what G-Force said....guess its preference...
http://www.geocities.com/n_dahi/
Old 02-18-2002, 09:13 AM
G-Forces's Avatar
Banned
Well I copied that directly from the 1999 G20 FSM. So it's a little more than preference.
Old 02-18-2002, 01:37 PM
ty423's Avatar
This could be the older generation motor...this guys car is a sentra se-r I believe....kind of like the P10 motors
Old 02-18-2002, 04:18 PM
G-Forces's Avatar
Banned
I know that guy, Naji. He's a little flakey and he drives a 98 SE-R. Same as the 1999 G20. I'm sure either way is fine.
Old 02-19-2002, 12:20 AM
JustinP10's Avatar
Well, my P10 FSM doesn't have the same steps as Naji's writeup, so that rules that idea out. ALthough, my FSM doesn't show the same steps as Jason's FSM, go figure? this is the loosening order.
3 8 12 10 6
2 13 5
1 7 11 9 4
To tighten:
11 6 2 4 8
12 1 9
13 7 3 5 10
BTW, this probably won't look correct, so move the 13 and the 1 to the center, of the center row and then the 5 and the 9 to the far right of the center row.
Justin McClanahan
95 G20
Polished Valve Cover for sale Axelthered05 Classifieds 0 06-22-2009 03:09 PM
timing belt covers/valve covers 1PhatCX '88 - '91 Civic | CRX | Wagon | Shuttlee 11 10-30-2004 09:16 PM
3.0 V6 valve job/valve cover gaskets 1988 VTISC007 4Runner/GX470 2 03-02-2004 11:21 PM
Valve cover color? G22DET General 43 01-08-2002 03:33 PM
