Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 09-26-2004, 08:51 PM
osutrapper osutrapper is offline
Creaking in front end when turning?
My car makes a creaking noise in the front end when I am going slow and turning. This also happens when I am turning into a driveway with a little curb. I have taken it to the dealership, but they can not recreate the noise. Is this something that comes with the car and I have to live with it or might there be an actual problem? Does anyone have any ideas?
Thanks to all
Old 09-30-2004, 07:22 PM
yogi_123rd yogi_123rd is offline
Re: Creaking in front end when turning?
If you drive slowly in a tight full turn and hear a "clicking" noise coming from the front wheels, then the CV joints are bad.
Old 10-30-2004, 07:42 PM
mcgunny mcgunny is offline
ball joint could be problem
I just had the same thing, had t replace ball joint assembly (375) the joint snapped but it does not matter you have to replace the whole assembly arm.
Old 01-21-2005, 02:50 PM
brian1175 brian1175 is offline
Eagle RSa's tires? If so thats your problem. get new ones.
Old 05-13-2005, 11:37 PM
jaimefontenot jaimefontenot is offline
I have the same annoying creaking sound when i turn too. It sounds like a squeaking door, but no one can figure out how to stop it. It doesn't seem to be the tires. It sounds like it is in the steering. Any ideas?
Old 05-16-2005, 10:55 AM
jphutch jphutch is offline
I had this issue and it turned out to be a torn lower ball joint boot. I got mine replace for nothing at the dealer because the lower control arm/ball joint(one assembly) was recalled previously.
Even if the recall has been done, as long as that is your problem than they may do it again, in fact they are supposed to.
It all depends on the dealer you bring it to as to the outcome. If one turns you down, try another. It certainly can't hurt. Just the cost of the control arm/ball joint is $200.
BTW, when they did mine(left side), they even replaced the end link on that side, which is another $50 part that I was planning on replacing if they didn't. I replaced the other side the same week. Good luck.
