Old 09-26-2004, 08:17 PM
Passivality Passivality is offline
Send a message via AIM to Passivality
Looking for 2 12in sub recommendations?
Okay, i have a duel enclosure ported competition box, retails 369 with 2 12in slots for subs. I'm looking for 2 subs to drop into it and not sure waht to get. I was looking at the sony xplodes. 1500 watts peak, 750 rms each. havn't heard great things about the xplodes tho. I'm most likely buying the subs on ebay and i'm not sure what to get. Trying to spend under 200 on the subs (keep in mind im buying them off the net/ebay so it will be around half price) any recommendations with specs would be great
Old 09-26-2004, 08:20 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: Looking for 2 12in sub recommendations?
I will not recommend you anything for that box. Due to one fact. The box is premade and tuned and built based on a certain woofer. You should make your own box or you wont necessarily be happy with the response of the speaker, but if you refuese to nix that box... Go ahead and get some 13kv2s from www.edesignaudio.com
www.cloudcity.deviantart.com
Old 09-26-2004, 08:28 PM
actually, the port lengths arnt yet cut, and i have a factory sheet that tells me how short to make the lengths of the ports depending on the vas or something with a VA and the db of the subs. Its sitting in my car i would run and get it but im tooo lazy, right now i have 2 12 pioneers in there that are 400 watts peak each that i payed 5 bucks for, i spliced my 6x9's and wired them to it for now untill i can figure out what kinda subs to get. But, like i was saying i can tune the box to the subs that i get.
Old 09-26-2004, 08:29 PM
it tune the ports by the VAS and FS of the sub
Old 09-26-2004, 08:33 PM
Haibane's Avatar
What amp are you using... you will want to tune to about 25hz-33hz... if you would like help on how to make those tuned to certain frequencys or help on what to choose, talk to the people over at edesignaudio.com if you go with an edesignaudio.com sub. I would recommend the 13kv2s. I would just like to know the amp as to which model of those to recommend
Old 09-26-2004, 08:35 PM
i'm not worrying about the amp right now, i want to get the subs first, then get the amp after i have the subs. im looking for around 400-600 rms
Old 09-26-2004, 08:37 PM
Haibane's Avatar
why are you looking for that rms? Woudl you like me to recommend an amp and a a set of subs for you?
Old 09-26-2004, 08:39 PM
Haibane's Avatar
how does 250 sound for 2 12s shipped?
Old 09-27-2004, 10:08 AM
250 for 2 12's shipped is fine, im just looking for the stats on them also
Old 09-27-2004, 11:23 AM
Haibane's Avatar
Spec
11Kv.2
13Kv.2
16Kv.2
Qts
.28
.31
.32
Qms
2.70
3.33
3.60
Qes
.31
.35
.35
Re
7.0
3.7
8.6
Vas
(Liter)
66
162
329
Sd (cm^2)
350
545
839
Fs (Hz)
24.8
21.5
19
Bl
19
15
15.9
MMd
109
135
179
MMs
116
142
193
Xmag
(mm)
14.0
15.1
16.3
Xsus
(mm)
19
21
21.4
Box Recommendation
(In cubic feet) - Click for info
Sealed
Vented
11Kv.2
.4 - .6
.8 - 1.0
13Kv.2
.6 - 1.1
1.2 - 1.5
16Kv.2
1.4 - 1.8
2.0 - 2.5
Old 09-27-2004, 11:40 AM
great thanks. btw, checked your deviant art, great shit man, ill look into getting those subs, still shopping around tho, do you own any your self?
Old 09-27-2004, 11:42 AM
Haibane's Avatar
I have installed a few of them, but I already had a sub I was satisfied with before I found out about edesign. I am ordering a 13kv2 right now .
Old 09-28-2004, 10:00 AM
alright thanks man, im debating between the 13kv2's and a set of audiobahns, the dub series
Old 09-28-2004, 10:15 AM
Haibane's Avatar
Audiobahns will be a whole lot harder to work with. Kv2s are pretty good for just throw in a box and play as far as sq goes. Audiobahns lean more towards spl and require a certain box... which is not the ones on the audiobahn page
