Old 09-26-2004, 07:27 PM
racecar racecar is offline
ohms
how many ohms does an amp need to be for 1 sub that is a single 8ohm?
Old 09-26-2004, 07:33 PM
jncodave jncodave is offline
Re: ohms
doesn't matter. you just wont be able to get an accurate estimate on how much power the amp is putting out because most only rate the power at 1, 2, and 4 OHMS
Old 09-26-2004, 08:30 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: ohms
I've never seen a single 8ohm sub....ghetto
Anyway, take the 4ohm power rating, divide it by 2, and you should be somewhat close.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 09-26-2004, 08:34 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: ohms
sr20... either shivas or tempests are single 8 last I checked
www.cloudcity.deviantart.com
Old 09-26-2004, 08:36 PM
Re: ohms
its a 10" rf that my friend has.
so hook it up to a 2 ohm load?
Old 09-26-2004, 08:40 PM
sr20de4evr's Avatar
Re: ohms
nope, shivas and tempests are dual 8
and no you can't hook it up to a 2ohm load, you can only hook it up to an 8ohm load since it's an 8ohm sub. What I was saying is you can find an amp, take it's 4ohm power rating, divide that by 2, and that should be somewhere around the power it puts out at 8ohm.
'01 Black Sentra SE
'05 Silver WRX STi
Old 09-26-2004, 09:27 PM
lucki17 lucki17 is offline
what would you do for a single 2 ohm sub?
Old 09-26-2004, 09:30 PM
sr20de4evr's Avatar
Re: ohms
you would hook it to a 2ohm stable amp....
'01 Black Sentra SE
'05 Silver WRX STi
