Old 09-26-2004, 06:37 PM
ebox2105 ebox2105 is offline
Unhappy Key Stuck in the Ignition
The key will not come out on my 91 S10 Blazer either. I went to the dealer and purchased the electronic ignition switch module for $22. I removed the bottom dash panels and dropped the stering column. The module is located on top of the steering column about a foot down from the steering wheel.
I replaced the inginition module with the new one and I also replaced the High Beam Switch which is located right next to the ignition module.
Put everything back together and the key will still not come out so it is not the ignition module. It must be the actual lock mechanism inside of the steering column. My high beam lights now work though. The whole job took me 2 hours to do.
I took the car to a professional mechanic and I am going to pay them to fix it.
I feel so ashamed of myself
Old 09-26-2004, 07:19 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Key Stuck in the Ignition
GJiggle the steering wheel a bit and see if it will come out.
