Old 09-26-2004, 06:06 PM
Gitrdone42 Gitrdone42 is offline
Send a message via AIM to Gitrdone42
LS/Vtec Swap
Hey im wondering if anyone knows where (or if) i can get a complete LS/Vtec swap for my 91 4dr i just bought. And when i say cmoplete i mean everything i need to do this swap.
Old 09-26-2004, 06:13 PM
91civicDXdude's Avatar
Re: LS/Vtec Swap
you usually cant buy an "LSVTEC swap", you have to build it yourself. try www.ebay.com for the parts, or your local import performance shop. www.hmotorsonline.com has a good reputation as an engine distributor, try them.
Old 09-26-2004, 07:29 PM
Re: LS/Vtec Swap
ohh i kinda figured that but wasnt too sure....ok i know of a few things i need ls block, vtec head, oil lines, mounts, tranny, shift linkage....is there anything esle that i need for it and does anyone know some sites i could use to get most of these parts?
Old 09-26-2004, 07:33 PM
Jetts's Avatar
Jetts Jetts is offline
Send a message via AIM to Jetts
Re: LS/Vtec Swap
if you dont know what you are doin i suggest not tempting to build one. Its a very precise process and one little mistake could blow your motor. If you are willing to try more power.
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Keith. higher then any mother fucker out there..... R.I.P homie..
Old 09-26-2004, 08:21 PM
Re: LS/Vtec Swap
im not the one actually doing it, im just gonna buy everything i need for it....im prolly gonna get one of my friends or a shop to o it for me
Old 09-26-2004, 08:39 PM
Jetts's Avatar
Re: LS/Vtec Swap
oh tight, im not sure on the parts so i cant help you there but goodluck and post some pictures when you do it
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Old 09-26-2004, 10:23 PM
Re: LS/Vtec Swap
i'm sure you could just pay a shop to get you all the parts and sell you an "ls vtec swap", but i meant they're usually not readily available from an engine distributor/importer
Old 09-27-2004, 12:55 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: LS/Vtec Swap
www.importbuilders.com
They're the best! Its gonna cost alot to buy there LS vtec motors. Check it out and email them to tell them what you want.
Old 09-27-2004, 01:13 AM
travagliante's Avatar
travagliante travagliante is offline
Re: LS/Vtec Swap
Okay The Shopping List(compleate as i can think of )
B18A1 or b18b1 block-from a 90-01 integra
B16a1 cylidar head from a jdm civic, 99-00si, 94-97DelSol Dohc Vtec
90-91 Teg Distributor.
90-91 Integra Intake manifold Compleate.
90-91 teg axles.
90-91 teg 5spd tranny
Hasport or HCP motor mounts
B-series conversion shift linkage
90-01 teg, 94-97delsol, 99-00 si Header
90-91 teg ecu with vtec activated switch or a jdm pr3 or pwo ecu( i think)
Thats all i can think of cause im tired and bored so n e one is welcome to chime in at anytime.
Personally since you really arent sure on parts, good deals or stuff just get a 90-91JDM SiR B16 Engine compleate. They run about 1000-1200 plus shipping for everything that you will need.
Old 09-27-2004, 08:22 AM
Re: LS/Vtec Swap
you need the b16a distributor, intake manifold, head gasket, transmission, etc. etc.
basically all you need is the b18a/b block and everything else you use from the b16a
Old 09-27-2004, 07:03 PM
Re: LS/Vtec Swap
aight thanks every1 who responded helps a lot....ohh and could u use a 94 up b18b1 block instead of the 90-91
Old 09-28-2004, 03:00 AM
mellowboy's Avatar
Re: Re: LS/Vtec Swap
Yes. You could also use the 90-91 teg distributor. You just gotta cut off the third leg.
Old 09-28-2004, 04:54 PM
SiZ's Avatar
SiZ SiZ is offline
Re: LS/Vtec Swap
ARP rod and head bolts! Verrry important!
Old 10-10-2004, 09:50 AM
LsVtec-97teg LsVtec-97teg is offline
Re: LS/Vtec Swap
i would use
gsr distributor, water pump(ls wont work at high rpms) and itr oil pump
b16 head and new cam gears
b18 block
p72 computer (Gsr computer) OBD-II
you might need a OBD-I to OBD-II converter if your car is OBD-I
you can get a vtec conversion kit on ebay that comes with the new oil sandwich and dowel pins and head gasket
arp head and rod bolts
if your head doesnt come with it your gonna need vtec solenoid, oil pressure switch and knock senor W/ wire harnesses because who ever does it is gonna have to add wire to ur computer and if u run it straight its is gonna be really hard for anyone to work on ur car in the future
Old 10-10-2004, 10:07 AM
forcefanajd's Avatar
forcefanajd forcefanajd is offline
Banned
Send a message via AIM to forcefanajd
theres no difference in the blocks....the only difference is the head.
