Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 09-26-2004, 05:31 PM
camry96 camry96 is offline
Check Engine light with Code P0420
Hi All,
I got the check engine light on just before a week. In fact this happened two times before. Once I had to change the egr valve to fix that. Now again i got that light on. I went to autozone for the code reading and found that "P0420"...Catalytic system efficiency below threshold. It this a serious problem? Can this cause anything bad to my car. I have 144K mile on the odometer. So I don't want to spend more. Is there any cheap fix? What might be wrong? Any idea?
Thanks,
PK
Old 09-27-2004, 03:39 PM
Joe W Joe W is offline
Re: Check Engine light with Code P0420
Pretty good bet that it is an oxygen sensor.
Old 09-27-2004, 08:00 PM
Erndog1369 Erndog1369 is offline
You most likely have a bad cat. converter. This code is saying that the readings of the oxygen sensor before the converter is almost the same as the sensor after the converter, meaning the converter is not doing its job. A scan tool can easily diagnose this by watching the wave forms of the two oxygen sensors, they shoud be competely different. If the wave forms are the same, then the cat. it shot.
Old 10-13-2004, 01:23 PM
Is there any big problem if I will NOT fix this and continue driving?
Thanks for all the suggestion.
PK
Old 10-13-2004, 06:09 PM
nipsirc nipsirc is offline
your problem would be during emission testing.
