Go Back   Automotive Forums Car Chat > Car Comparisons
Car Comparisons Compare any cars and find out what every body else thinks. Just refrain from making stupid comparos like Viper vs. Geo Metro :)
View Poll Results: Ls1 Camaro v. Srt 4
Ls1 Camaro 16 84.21%
Srt 4 3 15.79%
Voters: 19. You may not vote on this poll
Old 09-26-2004, 12:26 PM
Ls1GM Ls1GM is offline
2001 Camaro SS v. Dodge SRT-4
I need an honest opinion of which car would win between a Ls1 Camaro and an srt4 dodge. They are both manual and both are stock. My friend and I have been in an arguement and hopefully this will present an outcome. Thanks.
Old 09-26-2004, 12:36 PM
Rakshas Rakshas is offline
Re: 2001 Camaro SS v. Dodge SRT-4
The srt-4 is quick, but not LS1 quick.
Ls1-low thirteens witha good driver(13.2-3)
Srt 4- Mid to high thirteens with a good driver(13.6-13.9)
Old 09-26-2004, 04:32 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
There is no total outcome of posting this, It all depends on the driver and how well he can drive. Just because someone says the neons slower, doesn't mean it cant beat the camaro if the camaro driver can't drive.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 09-26-2004, 04:47 PM
kman10587's Avatar
kman10587 kman10587 is offline
Send a message via AIM to kman10587
Yeah, the SRT-4 is close enough that it could come down to the driver.
Old 09-26-2004, 08:01 PM
MARS's Avatar
MARS MARS is offline
Good driver vs. good driver = Camaro SS
Good driver vs. bad driver = Camaro SS
Bad driver vs. bad driver = Camaro SS
Old 09-26-2004, 10:12 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
srt-4 are running everything from 14.4 to 13.6
they don't run 13.5-13.1
Old 09-26-2004, 10:16 PM
mason_RsX's Avatar
mason_RsX mason_RsX is offline
Send a message via MSN to mason_RsX
If you took the same driver and times him/her in each car the LS1 would win...therefore I say the LS1 is the faster car
2002 Acura RSX Type-S
Originally Posted by SiGNAL748
I have an outrageously large penis.
Old 09-26-2004, 11:17 PM
kman10587's Avatar
Yeah, but it's easier to get a good launch with an SRT-4 than it is with an SS.
Old 09-27-2004, 12:14 AM
youngvr4's Avatar
STREET RACING GURU
i don't see how. when i was at the track, both srt-4's were having pretty hard times launching them. to were one of them rn a 14.8 then a 14.5
seems to me the maro ss runs consistant 13.6-13.3 at the track when i go. and i find rwd actually easier to launch then fwd. depending on the car
Old 09-27-2004, 12:23 AM
kman10587's Avatar
Well you know more about it than me, I just thought it'd be harder to find traction with 340 ft-lb going to your wheels. Then again, the weight shift is onto the rear wheels, so I guess that helps the SS.
Old 09-27-2004, 05:33 AM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
normally the SS would win, its RWD with a solid beam axle at the back excellent for drag racing.
the srt4 is FWD so weight shift works against it, and its quaife diff is helical aka torsen better suited for handling than drag racing(it will still help though)
However their perfomance is close enogh that a bad camaro driver can lose. Its easy to lose 3/4 of a sec or even more in a quarter with a bog or two much wheel spin.
Also altitude will play a huge factor. Here in Utah at over 4000 feet ls1 are low 14 sec cars. No matter how good the ls1 engines are, lack of air kills NA cars fast. On the other hand boosted cars suffer less from altitude and the srt4's in particular are designed to increase boost at altitude to compensate.
And on the other hand heat kills turbo cars very fast too, even more so than na
so low altitude high heat will give the ls1 more of an edge
hight altitude cool air will even the score quite a bit and even give the srt4 an edge
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 09-27-2004, 01:59 PM
youngvr4's Avatar
STREET RACING GURU
as a turbocharged owner.................. i hate heat
Old 09-27-2004, 10:27 PM
Neutrino's Avatar
Yaya Master
Re: Re: 2001 Camaro SS v. Dodge SRT-4
you should make a Ic sprayer. All you need is some home depot stuff and a bit if imagination.
It would really come in handy during scorching days when the IC is heat soaked.
(\__/)
Old 09-28-2004, 12:35 AM
youngvr4's Avatar
STREET RACING GURU
you know i was thinking about buying that N20 stuff
but, i never thought about a custom sprayer
another idea like that and i'm labeling you a genius
Old 09-28-2004, 01:42 AM
TatII TatII is offline
hahah i hate heat too. on the dyno i lost up to 20-30 whp from heat after 4 runs. so i have to have a 15 minute cool off time before hp is restored to normal.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
