Old 09-26-2004, 09:51 AM
croucher croucher is offline
Throttle Body
Hey, what would be the definiton of a better throttle body? Does that mean bigger? or what? I have a 99 3.8l firebird. What would be best for it? would i have to change anything on the car before putting a "better" throttle body on?
Old 10-07-2004, 10:56 AM
The Right Formula's Avatar
The Right Formula The Right Formula is offline
Send a message via AIM to The Right Formula
Re: Throttle Body
Better as in...? You can either port and polish your own to smooth things up a bit (smoother airflow) or buy a larger aftermarket. If you have a dremel (and the patience) you can do your own. Otherwise, do a Yahoo search for 'aftermarket throttle body'. Shaner (shaner.com?) has some nice ones, but a bit on the expensive side. You get what you pay for.
--jay
2002 Light Pewter Metallic Formula A4:
Cold Air Intake with sealed MTI Airlid, ported and polished TB, smooth bellows
Old 10-07-2004, 10:37 PM
Technical_Automan Technical_Automan is offline
Banned
What would be involved in port and polishing the throttle body? Is it just basically grinding away the sludge build up and cleaning it up, or is it more complicated than that?
Old 10-08-2004, 10:57 AM
Re: Throttle Body
there's a small 'lip' just before the TB blade. Port/polish grinds down the small lip and slightly increases airflow. Definately clean it too!
--Jay
