Old 09-26-2004, 04:52 AM
pheng911 pheng911 is offline
need help crx...
my hf crx when ever u step on the gas ur rpm falls down..we check and change are intake manfold, muffer, heater, wire harness, fuel injetters, fuel pump, new main relay, disturater and still doing the same thing..its not trowing no codes at all..u can drive it, when u lighly step on the gas and it back fires too..the max it can go is 25 mile only..if u step on the gas hard ur rpm falls down, and u hear some poping nose comeing from ur intake manfold..the car doesnt die.. anyone till meeh wut should i need to do..plz help
Old 09-26-2004, 09:12 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: need help crx...
Damn it sounds like a distributor problem. Does it pass 3000 rpm? If it doesn't...then for sure its bad. Also you might want to check the spark plugs and the wires. Also it could be a clogged cat?
Old 09-26-2004, 09:48 AM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Maybe your cat will cough up a hairball or smoke.
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 09-26-2004, 10:04 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
sounds like a timing issue. you spent alot of money no stuff that wasnt relavnt... wish I had the money to do that.
Old 09-26-2004, 10:05 AM
mellowboy's Avatar
That could be it. Maybe when you installed the distributor ...you messed up the timing. Get that checked also.
Old 09-26-2004, 11:16 AM
Hybrid1990crx's Avatar
kinda sounds like your rotor is loose.
Old 09-26-2004, 11:19 AM
mellowboy's Avatar
That could be it also...
Shaguar47's Avatar
Shit, I forgot about that. The rotor scew is famous for getting loose.
Old 09-26-2004, 11:31 AM
Forunn Daberator
mine was horrindusly tight, stripped out the head even though I was using the security bit, ended up having to drill it out.
Old 09-26-2004, 03:15 PM
will it could stay at 3000 if u getly step on the gas..but it cant relly stay tat long tho...if u step on the gas hard then the rpm drops and sometimes my motor die..wut can cost if u hear poping nose from ur intake manafo when u all the way step on the gas pedal..when we bought the engine it doesnt came with the distributor..we went and got a distributor from a freind (its an hf crx)..my freind car is running tat time also..we started it and the timeing was off by two or three lines..(is tat okay, and can tat be the reason)..does the timeing need to be rite on the mark..we took my car to the dealers and they say its my fuil injecter pulgs from my wire harness..we change are wire harness three times with new ones and it still does the same thing..anyone help..
Old 09-26-2004, 03:38 PM
mellowboy's Avatar
Yo just check out what we told you. Did you even try it out yet? Check the rotor to see if its on tight. I'm pretty sure the popping noise isn't coming from the manifold. CHeck the SPARK PLUGS. Then set the timing at whatever the stock time is at.
Old 09-26-2004, 05:09 PM
Forunn Daberator
if the timing is off it could be backfireing though the manifold. If the rotor is tight, swap the the spark plug wires around with the one directly accross from it (side with the other side one, top one with the bottom one), your timing may be 180* off.
Old 09-26-2004, 07:43 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
maybe ur outta gas, that was my problem... lol
1991 Honda Civic DX Sedan
Old 10-01-2004, 10:24 AM
big bad mohawk guy's Avatar
big bad mohawk guy big bad mohawk guy is offline
check your intake manafold(pvc joints).they were tweaked on mine>
1988 crx hf
cool air intake
#1 racing exhaust
sprint spings
B&M SHORT SHIFTER
gutted cat.
