Old 09-26-2004, 02:19 AM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
Y do i need Control Arm for a Alignment?
Ok, I got new tires for my car and needed an alignment. But the mechanic didnt do the alignment because he said i needed a left upper ball joint and a lower control arm and ball joint. Do you think i really need a lower control arm? And how the hell would i have messed it up? Do you guess think the mechanic is full of shit?
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
Old 09-26-2004, 05:41 AM
tyko909 tyko909 is offline
Send a message via Yahoo to tyko909
First you should take your car to the dealership and check if the recalls were done. I know that quite a few of these cars were recalled because of the ball joints. The other problems may have stemed from that.
Who needs speed when you push 155.8 dB.... I do!!!
6Bolt cyclone, 16g turbo, AWD, and a 5 speed
Old 09-26-2004, 01:27 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Y do i need Control Arm for a Alignment?
Its impossible to align the car with bad balljoints, thats why they looked. The lower balljoint is most likely the recall. The entire lower laterall link has to be replaced (the straight lower arm, the curved one is called a compression arm or link). It should be a free replacement as long is there is a given amount of play. If it failed the simple pre-alignment inspection, odds are its well beyond the service limit The upper one was never recalled, so you'll have to pay for that. But it should be cheap since the upper control arm can be reused, and replacing it beats getting killed or taking out someone else. Safety first!
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-26-2004, 02:37 PM
Killa_DSM's Avatar
Hey guys thanks for you replys. Ill check for recalls.
Old 09-26-2004, 02:56 PM
Killa_DSM's Avatar
Hey i found 2 safety recalls, which where "lower ball Joint/Control Arm Inspection and Front Passenger Seat Back". I also found Service Bulletins. What are Service Bulletins?
I used this web site to find the recalls. http://www.alldata.com/recalls/
Old 09-26-2004, 10:52 PM
AF - Advisor
TSBs are things that they arent recalling, but are letting you know there is an issue with it.
Kevin Jewer
