Old 09-26-2004, 01:16 AM
justlearning justlearning is offline
Send a message via AIM to justlearning
engine question
ok i know the only stupid question is the one u dont ask so please be forgiving... well i am planning on tryin to rebuild my first engine which i dont know anything about, but my dad can give some help (he knows how but was paralized and in a wheelchair now so cant get hands on) well i was wonderin i have a 305 tbi now and im gonna go w/ the 350. now the question is should i stay w/ the tbi or go carb, and if i do get a carb one (like out of an old vette mabey a 79 or 82) will it mess things up w/ the computer since it wont be fuel injected and if i dont use the computer wont it mess everything else up??? i cant ask my dad cause he only was able to work on carb'd vehicles before he got hurt. and also and even dumber question....if i do go carb will it clear my stock hood w/ a decent size air cleaner on it prob. 3 inch since its what i got now???
Old 09-26-2004, 03:09 AM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Re: engine question
I'm not the most knowlegable by any means, but I'd say stick with fuel injected.
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 09-26-2004, 10:24 AM
lckycharm713's Avatar
lckycharm713 lckycharm713 is offline
Re: engine question
in some cases, i think you can by pass the computer. also, get a cowl induction hood. if you want to use a big air cleaner. or you can cut the hood, i think that looks like hell. if your going to completely rubuild the 305, you should just pick up a 350. you will get more out of it and be happy.
2000 Mustang - just a V6 with lots of good looks
1974 Camaro - 350 4bolt main .30 over, turbo 350 trans w/ shift kit.
1999 F-150 Lariat 4x4 5.4L
"Only babies suck bottles (NOS)"
Old 09-26-2004, 01:16 PM
Re: engine question
no i am rebuilding a 350 and i was wanting to know about a: how does one go about goin from fi to carb, and keep everything else running normal and b: if i go carb will it effect hood creance more than tbi
Old 09-26-2004, 03:42 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: engine question
well ive got a friend who had exactly the same situation as you. he got another one of my friend's to work on his third gen. the kid apparently just removed all the injectors and stuff, put on a carb intake manifold, and spliced the injector harnesses together to complete the circuit. idea is that it tricked the computer into thinking that the injectors were there and firing. i dont know how it worked but the kid drove the car for a while afterwords. i know there is a better way to do it, but i thought that was an interesting story that was on subject...
*Better power-to-weight ratio than a C6 corvette*
Old 09-26-2004, 05:19 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
my advice would be to stay with efi. find a pair of L98 heads or aftermarket ones that are designed for 87 and newer intake manifolds. your tbi manifold wont bolt up to heads that were made before 1987. bolt those heads on to your 350 block and bolt your old manifold onto it and drop in the distributer.
or find an entire 350 from an 87-93 suburban. those had tbi and are a direct bolt in. your ecm will work just fine with a 350, but you can also get a prom from a 350 equiped vehicle or a have one custom burnt.
if you switch over to carb just drop in an HEI distributer. your existing distributer wont with a carb. it will fire just fine but it wont advance the timing during acceloration, there may be a way to make it work but i dont know how. you'll have to either get a pressure regulator for your fuel pump, or get a mechanical one that bolts on to the block. your stocker puts out about 15psi and that will blow the needle valve back in the carb and cause flooding.
and yes your hood will clear just fine.
Old 09-26-2004, 11:02 PM
Re: engine question
thanx alot man u dont know how much i appreciate everyones help!!! i just want to let u guys know its people like u who make ametures like me really want to learn these things that interest me by providing insight that would be a huge block in the road to someone lacking the knowledge
Old 09-26-2004, 11:08 PM
Re: Re: engine question
I could say the exact same thing
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 09-27-2004, 08:03 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: engine question
my advice, just for the ease of installation, is to keep the FI. if you are swapping in a 350 for the 305, its a direct swap, all the accessories, all the parts that bolt to the engine will bolt right on. if you go with carb, youll be splicing wires, modifying harnesses, and in a whole messy situation that no offence, i dont think you are ready for. The only change youll have to make with the 350 is to get the Throttle body off of a truck at the junkyard orriginally equipped with the 350, i think its the K motor. the Throttle body here is larger and allows more airflow, or you can order a direct replacement from holly with much more airflow. I think even though FI is said to be more complicated than Carbs, that you will have a much simpler job if you keep the FI.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 09-27-2004, 11:44 PM
Re: engine question
so your sayin i can use any old 350 engine then just get a throttle body and replace it where the carb was right...if thats the case then ive got a world of possibilities because i was worried about the power of a old suburban motor really all the power i want is around 300-350 but i just dont like how damn slow my 305 is off the line although i do need a tune up
Old 09-28-2004, 01:13 AM
TechX's Avatar
TechX TechX is offline
I this going from Fi to carb is a step down hill. It all depends on what this car will be used for. If you just want a street racer then build the 350 and throw a carb on it would be just fine. If you might drive this car in winter of daily then stay fuel injected. You can use the 305 hardware but it is not ment for a 350. I do believe it will work just fine though. If I were you I would find a good junkyard that has a Fuel injected car similar to your and tell them you want to trade your 305 with Fi for just a 350 Fi or the engine and all. They might do that if you drive the car in and let them here it run. Have fun whatever you do. Working of your car is always fun.
Old 09-28-2004, 10:03 AM
89IROC&RS's Avatar
Re: engine question
the only difference between a 305 and the 350 is the water jackets (which wont allow you to bore it out to a 350) smaller bore and obviously the pistons. other than that they are EXACTLY the same engine. so you can build up a 350 on an engine stand next to the car, unbolt the 305, pull it out and put it next to the 350, and swap EVERYTHING from the 305, to the 350, and it will look externaly the same because it is. then take the 350, and drop it into place where the 305 was. physically everything is exactly the same from the 305 to the 350, the engine mounts the tranny (except the T5, use that at your own discresion but dont say we didnt warn ya) rear end, suspension, fuel pump yadda yadda, all exactly the same.
one thing you will want to change, is the throttle body, the stock unit was small even for a 305, so with a 350, it will be the cork in the system, get a bigger one, like i said before.
one thing you will have to do, if you want the engine to run its best, will be to get the PROM chip out of a 350 equipped truck, probly the same one you get the Throttle body out of, and put it in your computer. You will have to find a doner truck from the same year as your car though, as PROMS changed over the years and are not interchangeable.
Old 09-28-2004, 01:02 PM
4onFloor's Avatar
yes and no. 87 and newer blocks have the dipstick on the passenger side. 86 and older have the dipstick on the drivers side. 87 and newer exhaust manifolds will block the dipstick hole on an engine that is 1986 or older. the only way you can use a motor that is 1986 or older is to buy a pair of headers, or get different exhaust manifolds and get a custom fabbed Y pipe.
your intake manifold like i said before wont bolt up to heads that or 1986 or older because the center 4 intake bolt holes are canted.
Old 09-28-2004, 08:09 PM
Re: engine question
no thats not what im askin even though all this is still very helpful. i want to know if i could lets say get a 350 out of a car probably pre 87 and its a carb engine, if i could just take the carb off and go get a throttle body off lets say a suburban tbi and bolt it in were the carb was on the engine or is there more to it than that?? and i would probably get a edelbrock intake and a mild cam along w/ a complete rebuild kit (from crank to freeze plugs). so i know i couldnt use my manifold but from what i hear the stock intakes r no good anyway. now like i said before keep in mind i dont really need much more than 350 hp and not more than 400 ft lbs. due to this being my daily driver and we do get snow in the winter alot. i also dont want the compression to be more than 9 to 1 because i use just regular unleaded so i know i will probably not go w/ 64 cc heads just get the 74 instead and have them shaved and just use domed pistons. i know its not the best recipe but i think it should do if not let me know and i especially need to know about the carb thing...sorry for the length thanx
Old 09-28-2004, 09:03 PM
4onFloor's Avatar
a throttle body wont bolt in place of a carb without an adapter plate. throttle body's use a 3 bolt triangular pattern and most 2 and 4bbl carbs use 4 bolts
