Old 09-25-2004, 11:09 PM
comtac comtac is offline
Question turbo 350 problems
Hello, new to the forum wondering if someone could help me troubleshoot a problem with a Turbo 350. Chev 1/2 ton sat for about 2 years, I started up the ol' girl no problems and drove it out of my shop. Then it stopped on me, not the engine but the drive. Everything looks OK as far as the tranny fluid. I changed it and tried to drive the truck again with no luck. It is a 4X4 and if I have it on jack stands it will turn all the wheels no problem 2 wheel or 4 wheel. As soon as I put the wheels to the ground, there's no power to the drive.
Don't know what's up. Any help would be appreciated.
Thanks in advance.
Old 09-26-2004, 12:24 PM
dieselfumez dieselfumez is offline
You mentioned changing the fluid, did you also change the filter as well at the time? Kinda sounds like a restriction somewhere in the bottom end of the trans. After sitting all that while it might have pulled all the junk in the fluid into it.
Old 09-26-2004, 12:38 PM
broughy84's Avatar
broughy84 broughy84 is offline
Re: turbo 350 problems
what year is this truck? are you positive it is a 350 turbo and not a 700r4?
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 09-27-2004, 10:46 AM
I didn't change the filter.......don't know why I didn't I'll give it a try and see. It is an 81 with a turbo 350. The 700R4 has the overdrive doesn't it ?
Old 09-27-2004, 10:47 AM
Is there a simple way to "blow out" or flush the lines to check for blockages???
Old 09-27-2004, 12:26 PM
broughy84's Avatar
yes, 700r4 is overdrive. I have heard someone take the bottom one loose at the trans and put a hose on it and run the hose to a bucket. Start the truck, flush about a quart out, and at a quart and do it again.
Matthew Brough
Old 09-27-2004, 12:34 PM
No ill effects to the tranny by doing this???
Old 09-27-2004, 07:23 PM
broughy84's Avatar
i don't know i have never done this.
Matthew Brough
Old 09-29-2004, 12:19 AM
SpitAndDirt's Avatar
SpitAndDirt SpitAndDirt is offline
Ive done the flushing of the tranny by removing the cooling lines before, it really gets quite a lot of fluid out really quickly. Just remove the lines, put some hoses over the ends and route into a bucket or pan of some sort, start the engine until you don't get a steady stream of fluid any more. Turn the engine off, connect the lines back up, and refill the tranny. Easy! Depending on the year, past abuse, and tranny model (4L60, 4L60-E, or 700-R4) you may have some solenoids that may need replacing. I can't tell you for sure, but I do know that once you know for certain your transmission, you can visit www.atsg.biz or your local transmission parts supplier and pick up a manual specific to that tranny for about $15 to $25. It will help you to diagnose the problem with a whole lot more accuracy. Hope this helps -Chris
Old 10-01-2004, 04:36 AM
Yo Dog Yo Dog is offline
If the filter doesnt solve the problem its probably burnt up clutches or bad converter. If it looks that way pour you a can a B-12 in it. It sounds crazy but ive seen it work before. The B-12 swells the cluthes which will maybe make it work again for a while. Just a cheap fix. Or just pull it and get it rebuilt turbo 350's are inexpensive to rebuild or get rebuilt, theres not much to them. But yea give the B-12 a try for shits and grins you cant hurt anything.
Old 10-01-2004, 12:36 PM
What's the cost difference between rebuilding and buying a rebuilt. I have priced out a rebuilt. It's only $420.00 but I don't know what the cost is of rebuilding................
They say you are what you drive:
little old, little rusty, but trusty
Old 10-02-2004, 11:39 PM
trannyman52 trannyman52 is offline
does this thing have reverse,,good????? or doesn't it move at all?????
Old 10-03-2004, 12:42 AM
madcatter madcatter is offline
Don't laugh, but this happened to a friend (no, not me) about a month ago pulling into his driveway. He had the truck in the shop ready to pull the tranny when he realized the transfer case shifter was in neutral! Just a thought.
www.kowboykustoms.com
Kowboy Kustoms trick paint
Old 10-03-2004, 09:53 AM
All the gears work when it is up on blocks. The wheels turn in 4 or 2 wheel drive. Checked the transfer case out, but like I say, in 4X4 all wheels turn. It's just when I try to move the truck in any direction it won't push itself.........
Old 11-22-2004, 06:29 PM
ttwwpp ttwwpp is offline
If you have a good reverse on the ground and no forward (or vice versa), you have a trans that need overhauling.. sorry...
Tim
Trans tech 25 years..
