Old 09-25-2004, 10:23 PM
DJHyperXK2004's Avatar
DJHyperXK2004 DJHyperXK2004 is offline
Send a message via AIM to DJHyperXK2004
Question ECU Code # 20..??
what does it mean when I get this code???
"Code 20 (20 flashes) Electric Load"
1990 DX Hatch
17" 5Zigen Copse Rims
CIA, 4-2-1 Header
H/F Cat, 5Zigen Exhaust
Circle Earth kit
B swap in the spring???
PIX OF MY CAR
Old 09-25-2004, 10:27 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: ECU Code # 20..??
It means you'll spend a lifetime tracing wires. Just like its taking a lifetime for your sig to load on dailup... thanks alot assholes.
Old 09-25-2004, 10:32 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
LoL
Old 09-25-2004, 10:46 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
could possibly be the alternator going bad.
there is a diagonistic cap at the dirver left foot, under the mat. if for some reason that cap is taken off or comes loose, it could cause that error code.
i'm sure somebody will suggest checking the main relay as well.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 09-27-2004, 10:48 PM
it was the battery neg not grounded to the firewall of the car, after the Circle earth install...
1990 DX Hatch
CIA, 4-2-1 Header
Circle Earth kit
PIX OF MY CAR
Old 09-27-2004, 10:52 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
whats the circle earth kit?
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 09-28-2004, 12:22 AM
Re: Re: ECU Code # 20..??
Circle Earth System...
By utilizing a 24 karat gold plated distribution block and multiple grounding points, improved idle
and drivability are often obtained as the additional grounding points equalize resistance and
voltage between various ground points...
1990 DX Hatch
CIA, 4-2-1 Header
Circle Earth kit
PIX OF MY CAR
Old 09-28-2004, 08:57 AM
Well hey sorry, that everyone but you, got the memo, but there is this cool new thing that called a cable modem, you should probably look into it!!!
1990 DX Hatch
CIA, 4-2-1 Header
Circle Earth kit
PIX OF MY CAR
Old 09-28-2004, 12:20 PM
CRXsiZCpa's Avatar
CRXsiZCpa CRXsiZCpa is offline
Did you try resetting the ECU? Open the fuse box under the hood and remove the hazard fuse for like 30 seconds. Then just pop it back in and let the car idle for a little.
Old 09-28-2004, 01:03 PM
yea, i made sure all the ground wires were all set, and i reset the ECU.. so code 20 is gone!
So far im down to only Code # 1(had it forever) ..... and now since ive installed that header and high flow cat, and exuast, i get the check engine light after about 5 min of driving every time?? any way to fix it??
I also get code 16 once iin a while
1990 DX Hatch
CIA, 4-2-1 Header
Circle Earth kit
PIX OF MY CAR
Old 09-28-2004, 06:53 PM
Onimacus's Avatar
Onimacus Onimacus is offline
Send a message via AIM to Onimacus
Maybe he pays his own bills and can't afford cable, why do you have such a long movie for your sig anyway, it doesn't even have anything to do with Honda's or cars.. or being a DJ...
Travis
Old 09-28-2004, 09:32 PM
well if your sig worked, im sure we could say somthin about yours...
and when i feel like it, ill change mine
1990 DX Hatch
CIA, 4-2-1 Header
Circle Earth kit
PIX OF MY CAR
Old 09-30-2004, 12:52 PM
Onimacus's Avatar
My sig is a picture of my car, but the hosting site has been down for about a week
Travis
