Old 09-25-2004, 09:27 PM
eespidie eespidie is offline
coolant low ???
my coolant low light in my 1992 p.a. pops on occasionally... however my coolant is not low. i recently had to change the petcock... and after that used some sealer for a crack in my radiator... do i have a problem ??? or is my light just screwed up ???
thanks
Old 09-27-2004, 09:15 AM
aarcuda aarcuda is offline
Re: coolant low ???
well, if the coolant isnt low, and the light comes on.... then theres a problem with either the sensor or the circuit that lights the light.
Old 09-27-2004, 01:16 PM
parkavenuechrome parkavenuechrome is offline
If you put sealer in the system , the sealer could have the sensor sticking causeing the light to come on.. flush out the tank and you should be ok.
Old 09-27-2004, 08:31 PM
Thumbs up
thanks,
I will check the sensor and the circuit...
your help is appreciated.
Old 09-30-2004, 05:54 AM
deadring deadring is offline
Re: coolant low ???
mine does that to.. where is the sensor? i didn't see it on top on the expansion tank...i wanna clean mine to.. if that doesn't help, i pulling the bulb out.. it's useless anyway with a temperature gauge in the car.
Old 09-30-2004, 09:39 PM
Re: coolant low ???
i know nothing about bulbs or temperature gauges... but a guy told me if i have wires running to my plastic tank i'll have a sensor there... and he said something about one on the outside of the radiator...??? i just know what i'm told.
