Old 09-25-2004, 09:07 PM
yamahaboy's Avatar
yamahaboy yamahaboy is offline
Send a message via AIM to yamahaboy
94' Camaro
Over the winter my dad an i are going to buy probally at 94' Camaro. we will probally buy one that needs stuff like brakes exhaust wheeles and all that fun stuff. we want to do ALOT of performance mods. we will probally keep the stock motor (the v8) but do stuff like new heads. what kind of air intake should we buy? or should we make our own? how bout exhaust? we want to do to the whole exhaust. We want to redue the whole suspention. this will be my first car for when i turn 16 and ill be racing it at the race track. (highschool program). pretty much we know what were doing except when it comes to the motor. thanks!
Eric
03 yukon denali xl 6.0L
00 audi a6 2.7t quatro. twin tubo (awd)
03 dragster- runs the 1/4 in 8.41 at 160mph......468 big block chevy
Old 09-25-2004, 09:24 PM
94ChevyCamaro's Avatar
94ChevyCamaro 94ChevyCamaro is offline
Re: 94' Camaro
for the air filter...k&n cold air all the way
Old 09-26-2004, 03:21 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: 94' Camaro
intake - slp
exhaust - any 3" cat-back, i guess slp loudmouth
headers - edelbrock long tubes
i would do the LT4 conversion
there are a lot of threads on LT1 performance, run a search on the forum and you should get good info...
*Better power-to-weight ratio than a C6 corvette*
Old 09-27-2004, 04:16 PM
yamahaboy's Avatar
Re: 94' Camaro
i think were going to do the lt4 converson. what about suspention??
Old 09-27-2004, 06:25 PM
twdz28 twdz28 is offline
Re: 94' Camaro
Oh boy could I ever have fun with this one!!!
CAI! K&N
Z06 85mm MAF! Reprogrammed for the LT1
Vortec elbow
52mm throttle body
Forget the LT4 Conv you can make more power with less money spent... You can have you stock LT1 heads ported and polished and they will out flow the LT4 heads... Or you could buy the LT4 heads and have them reworked to flow even better... Anyways the LT4 cam is small in my opinion... This guy sells cam packages, give him a call he is a real good guy to deal with http://www.cmotorsports.com/
LT1 Cam Kit includes:
LT1 Cam (Incl. Our Lobes, Comp Lobes, any combo)
Spring Kit (EX-612, EX-614)
Comp Pro-Mag RR’s (1.6 or 1.5)
EX Blue Band Valve Seals
EX Hardened Pushrods
Cam Swap Gasket Kit
$599.97
*Comp Cams 7/16 Studs are an option for this kit at $34.97
**Comp Cams R Lifters for LT1 are an option at $199.97
***Kit Price Without Roller Rockers 349.97
Long Tube headers are a must any company that sells them just make they are Jet Hot coated...
Borla, GMMG, Corsa are all good cat back systems.
Suspension, BMR, Global West, Spohn are all great for this car... Make sure to get a track link or torque arm and relocation brackets to drop you ETs...
LT4 Knock module
Custom ECM tuning
LT4 Timing Chain
Get rid of the Air pump, EGR, and Cat.
95 Z28 Black on Black on Black. Mods: 355CI and lots more...
Originally Posted by Mordant
I'd say if they ask about material possessions then it's fair game to ask them what kind of underwear they wear, may as well get both sides expectations on the table as soon as possible.
Old 09-27-2004, 06:41 PM
Dober89 Dober89 is offline
Re: 94' Camaro
www.spohn.net makes some great suspension parts for fbodies!!
Old 09-27-2004, 09:05 PM
yamahaboy's Avatar
Re: 94' Camaro
thanks alot!!! those are great ideas for us. thanks!
Old 09-28-2004, 02:06 PM
Re: 94' Camaro
for suspension i like BMR fabrication for all your control points. edelbrock has good shocks, also the HAL QA1 adjustables. eibach is good for springs and you should look into getting a posi-trac differential, if you really want to take some turns...
Old 09-28-2004, 02:10 PM
DiabloGT's Avatar
DiabloGT DiabloGT is offline
Banned
Re: Re: 94' Camaro
CAI! K&N
Vortec elbow
52mm throttle body
Cam Swap Gasket Kit
$599.97
LT4 Knock module
Custom ECM tuning
LT4 Timing Chain
where do u get that MAF from the ls6 to lt1 from? can i please have a link cause i was thinking of this granatelli one but i wanna know about this one
Old 09-28-2004, 02:31 PM
Re: Re: Re: 94' Camaro
do not get the GMS one, it sucks and your fuel tables will be off...
You can get the Z06 on from GM or SLP... SLP sells the one set up for the LT1... However if you do get a GM one or the SLP does not work right, I have the MAF Table for it. All you will need is the OBD1 cable and a laptop or Desktop that you can wheel close to the car... I can email you the program to do it... Any other questions about this take to the PM's...
Old 09-28-2004, 02:34 PM
DiabloGT's Avatar
Banned
Re: Re: Re: Re: 94' Camaro
i pmed you, can you please send me the link for the z06 MAF thanks
Old 09-28-2004, 04:41 PM
yamahaboy's Avatar
Re: 94' Camaro
i have a quick question about the programer. when i do the whole lt-4 and exhaust will i still beable to use the programer? i think ill beable to but will i have to order it special? and one other thing. would you order the lt-4 kit or buy the parts seporate? ive read that you can get more power cheaper from another cam.
Old 09-28-2004, 04:49 PM
DiabloGT's Avatar
Banned
did you have to do the ob1 wires and laptop thing with the one from slp the z06 maf or do i have to do nothing besides install it?
thanks
Old 09-28-2004, 04:50 PM
Re: Re: 94' Camaro
Contact madz28.com or pcmforless.com for all you ECM tuning needs unless you bring it to a shop and have it dyno tuned...
I would order the parts separate because you can make more power with a better bigger cam... As I said before I think the LT4 is a small cam... You could order the complete LT4 kit with heads and just (sell the Cam and Roller Rockers) but (keep the Heads and Intake)...
Old 09-28-2004, 07:52 PM
yamahaboy's Avatar
Re: 94' Camaro
thanks alot man. i was wondering if there is any sites online or if u know where i can get a camaro z 28 for around 3000 or possibly 4000. we dont want to spend 6k for a car and then dump another 5-8k into it. by the way im looking for a 1994 and in illinois
