Old 09-25-2004, 07:24 PM
sharkalvarez sharkalvarez is offline
car wont turn
matbe someone can help me my brother had a small accident and crashed his mustang but was hit on the left front fender the air bags did pop but the motor is still good. my question is we try to turn the car on but it wont turn we thought it was the battery so we charged it but it wont turn i was wondering if it has a kill switch that you have to reset i know it has a fuel cut off but the car just wont turn not even a little bit can any one help.
Old 09-25-2004, 07:26 PM
ec437's Avatar
ec437 ec437 is offline
Re: car wont turn
mmm... run-on sentences! my favorite!
SoStAsSaId: and the flight attendant is cute... if i was a lesbian, i'd join the mile high club
<---call this number
Old 09-25-2004, 07:33 PM
Re: car wont turn
i didnt know this was english class
Old 09-25-2004, 08:06 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
Re: car wont turn
if i understand your problem correctly, you've probably got starter relay problems. i can't be sure of this, of course. do you hear any noise when you turn the key? a click, a bump, grinding, anything?
first thing is to get a circuit tester and see if you get voltage to the starter relay exciter wire with the key turned to 'start'. if you do, use a screwdriver to connect the battery side of the starter relay to the exciter wire terminal. if it still fails to crank, test the voltage across the battery posts. if it reads low, the problem is your starter.
that there's the basics of how to diagnose starting problems. if none of that works, the big wires are at fault.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 09-26-2004, 03:15 AM
malcolm brumley malcolm brumley is offline
Re: car wont turn
Check for a broken black ground wire connecting to the core support. They all have to be connected.
macbrum
