Old 09-25-2004, 06:52 PM
91f-bird 91f-bird is offline
Send a message via AIM to 91f-bird
Angry radiator fan relay location
ok im starting to get pissed with this car...i changed the radiator fan motor, checked the fuses, changed the temp sensor, checked the wiring,i need to know exactley where the relay is and what it looks like ...i have no clue ...any help would be great...thanks alot
Old 09-27-2004, 06:01 PM
GirlInAHotRod GirlInAHotRod is offline
Send a message via AIM to GirlInAHotRod Send a message via Yahoo to GirlInAHotRod
Re: radiator fan relay location
There are several relays and switches in the system. 9 times out of 10 it is a switch when an electric fan doesn't work.
You could take it to a mechanic and have him point out the relay to you.
Are you sure the fan is not working? I am not really sure of your question. Fans don't run all the time. (they go on and off) But, you prolly know this.
Also would the relay be in the fuse box under the hood?
Old 09-28-2004, 08:57 AM
i will take another look.. thanks for the help..and yes i know that it goes on and off i let it run till it gets hot and it still wont pop on so ill have to try something else
Old 10-10-2004, 06:00 PM
tomminajar's Avatar
tomminajar tomminajar is offline
Turn on the car and start the AC - fan should come on.
Also it should come on if you ground out the ALDL like you were pulling out trouble codes...
What size engine in your 91 V6 ?? The relay is on the driver side firewall there are 3 relays .
