Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 09-25-2004, 04:56 PM
89tracerman's Avatar
89tracerman 89tracerman is offline
Drive shaft
ok i just spent over $1000 on my RX7 in one month and i was wondering if the drive shaft i used is ok i bought a drive shaft at the junk yard for $50 and when i had both the original and the one i just bought i noticed that the one i just bought was like 2 times bigger (fater) I installed it and the car runs fine but i dont know if it was a good idea to use it. any help will be apreciated thanks.
Old 09-26-2004, 08:08 PM
Re: Drive shaft
does the drive shaft make a difference?
Old 09-26-2004, 09:22 PM
projectsupramk3's Avatar
projectsupramk3 projectsupramk3 is offline
Send a message via AIM to projectsupramk3
Re: Drive shaft
I'm assuming you have an automatic for you to be able to bolt in a TII driveshaft. No difference in the performance, only that your DS is now going to be the last thing to break in the drivetrain.
Old 09-26-2004, 09:29 PM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
Re: Drive shaft
lol
RX-7 TII
Old 09-27-2004, 08:58 PM
Re: Drive shaft
no sorry its a 5 speed and it did fit perfectly on my car
Old 09-27-2004, 09:59 PM
Re: Drive shaft
Forget what I said about the TII, I don't know what I was thinking mentioning a TII driveshaft with a n/a transmission. What you found is the larger n/a driveshaft, I've only seem them on S4's sport models. Same diameter as the TII but with the correct ends.
Old 09-27-2004, 10:04 PM
Re: Drive shaft
is there any other parts i can get from the sport RX7 to make my car faster?
