Old 09-25-2004, 04:14 PM
danh0ward danh0ward is offline
1998 S-10 Reverse Lights Not Working
About 5 months ago I noticed that my reverse lights were not working all the time (intermitantly) Now they do not work at all. I assume it is the switch because the fuses are all good and the bulbs also. If you know a fix for this problem, Please reply. Any help will be appreciated.
Old 09-25-2004, 08:55 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 1998 S-10 Reverse Lights Not Working
There is a reverse light switch on the transmission.
I would grab a chilton's or haynes repair manual and do some exploring.
Old 09-27-2004, 10:45 PM
thejacobhartman thejacobhartman is offline
the switch is accessible from underneath. a little tough if it is a zr2 but not too bad otherwise. you can find it in a haynes or chiltons manual or go into your dealer's parts department and they will usually show you in their manual. juat unplug it and replace it the switch is only about $10
Old 09-27-2004, 11:35 PM
Thanks for the help guys, Good thing I have a lift at work, I may have it done by tomorow.
Old 09-29-2004, 11:53 AM
Done!!! Total cost, $12.00 and 10 Min. Thanks for the help you made this a real easy job. now for the ball joints.
Old 09-29-2004, 12:50 PM
BlazerLT's Avatar
AF -Advisor
So what did you do exactly?
Old 09-29-2004, 09:37 PM
It was simple, I got the part went to work and put it up on the lift, unpluged the wires, grabed a 7/8th deep well and a ratchet, remove and replace, pluged back in and went home. the switch was easy to access however I did get a small burn from the cat converter.
Old 09-29-2004, 09:44 PM
BlazerLT's Avatar
AF -Advisor
ah, war wounds.
you won the battle though.
Hope you win the war.
Old 09-30-2004, 11:10 PM
all weapons drawn.
Old 10-01-2004, 04:07 PM
BlazerLT's Avatar
AF -Advisor
Nice.
