Old 09-25-2004, 03:40 PM
henrymv henrymv is offline
Flasher button
Doe anyone have teh wiring diagram for the flasher button on a 90 Accord EX?? What I am seeking exactly, which wire is the hot wire, the ground wire, and what wires go to the lights??
Thanks in advance
Old 09-25-2004, 07:48 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
flashers, as in high beams?
Old 09-26-2004, 07:08 AM
Re: Flasher button
NO...flashers as in hazzard lights....
Old 09-27-2004, 11:20 AM
AccordCodger AccordCodger is offline
Re: Flasher button
You'll find it in a Chilton manual (and probably a number of others). Can't post a scan --- copyright.
Old 09-27-2004, 11:50 AM
Re: Flasher button
Thanks fo rthe info...Chilton's only shows the flaher, but does not show which whires go to were...would you email me the info to my private email??
Thanks
Old 09-27-2004, 12:12 PM
Re: Flasher button
My Chilton (p/n 8255) shows the Hazard Warning Switch (I take it that's what you're referring to?) and the wires from it.
Sorry - copyright means "don't copy," not "don't get caught."
Old 09-27-2004, 12:15 PM
Re: Flasher button
MMMM...mine does not show what wires are hot and which go to which flasher....Can you please tellme which one is the hotwire and which goes to the front right and front left turn signals?? Is the hot wire the red/black wire??
Old 09-27-2004, 12:58 PM
Re: Flasher button
My diagram doesn't have a red/black wire. The switch has 6 wires --- 2 in: yel/wht hot when ign on, wht/grn hot always, and 4 wires out - grn/yell to right, grn/blue to left, grn/wht to relay, grn/red to relay & turn signal switch
Old 09-27-2004, 01:01 PM
Re: Flasher button
thanks...that helps alot....i appreciate your help and time? Do youknow how to turn off the door chime??
Old 09-27-2004, 04:18 PM
Re: Flasher button
No idea - sorry.
